RECORDING LEVEL
what's the best way to get a high record level I must always normalize my recordings
gear yamaha trb bass and bass pod xt thanks |
Re: RECORDING LEVEL
If you're recording 24-bit (which you should), you don't need high recording levels. In fact, your mixes will probably sound better with moderate recording levels. A lot of pros record at -18 on average. Normalizing is simply a calculated gain increase. You can raise gain so many other ways (faders, plug-ins, aux busses, etc.) there's no need to normalize each track.
rockrev
End world poverty: ONE |
Re: RECORDING LEVEL
But if you would prefer getting 'hot signals' and not normalizing, always keep your OUTPUT (left-most knob on the POD) at its maximum, and plug directly into one of the 002's preamps and adjust its gain accordingly (assuming you're using 002 or mbox).
Rock on Ben |
Recording level vs playback level.. | DigiDudeski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-04-2009 05:00 AM |
level recording help! | chal7ds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-29-2005 01:24 PM |
So what level should I be recording at??? | spong | Pro Tools TDM Systems (Mac) | 3 | 04-07-2002 01:23 PM |
TDM recording level | marcelloz | Tips & Tricks | 3 | 05-17-2001 05:27 AM |
low recording level | Ricco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-14-2001 05:35 PM |
