Old 11-01-2007, 01:33 PM
Violet Violet is offline
Default Changing the size of Midi notes in \'note\' mode
You know how you can adjust the size of tracks to view you regions larger...
When you view the track in 'Note' mode(volume, region, block) how do you zoom in on those tiny notes?
PT 9.0.3
Windows 7 64 bit, 2x i7 PCs, 24GB, 3 SSD's, 5 HD's
....and a couple other toys.
Old 11-01-2007, 03:02 PM
imagin imagin is offline
Default Re: Changing the size of Midi notes in \'note\' mode
Try Alt-mouse wheel, to zoom in.
or select the region and press e (edit mode), e to return.
hope this helps!
Iain
Old 11-01-2007, 06:39 PM
As Iain has hinted at, try Zoom Toggle if your running version 7.3 or higher. The Pro Tools Reference Guide has further information on this and also DigiZine Spring Edition 2007 (MIDI Ditty) covers this in more depth.
filosofem
Aaron Mulqueen - 001 HD Native
Old 11-01-2007, 08:46 PM
No, no I mean make the notes bigger length wise, not width. So you the piano keys off the the left appear to be bigger, and the notes are fatter, not longer. thanks for any help.
PT 9.0.3
Old 11-01-2007, 09:37 PM
Try the Trim tool.
filosofem
Old 11-02-2007, 01:10 AM
Try Alt-shift-ctrl-mouse wheel.
Right click on the keys for the track height option.
Iain
Old 11-02-2007, 01:07 PM
thanks guys alt ctnl shift mouse wheel is it!
PT 9.0.3
Old 05-26-2008, 11:02 AM
DaveBCC DaveBCC is offline
This was helpful to me as well, but it changes the size of notes for all tracks. Does anyone know a way to change note size for a single track? I tried every method I could find in the manual, and every combination of alt/cntl/shift/mouse button/zoom controls I could think of.
(I am running PTLE 7.3 on Win XP SP2)
Thanks for any ideas
Old 05-26-2008, 11:24 AM
shea shea is offline
I think what your all trying to is this.
highlight your midiregion trk by double clicking and go to event/event operations/change duration,and oposite (set all to) change the box 000 to say 200 or what ever you like and this will make the midi notes that size.you can also highlight the snare for instance by hitting e on the wee piano which will highlight all the notes of the snare,and do the above.
hope that makes sense.
seamus
Old 05-27-2008, 08:51 PM
audiogeekzine audiogeekzine is offline
Is this what you're looking for?
http://www.audiogeekzine.com/MIDI_Height.jpg
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Drawn MIDI note length only staccato notes, regardless of note length kingofallwookies Pro Tools 11 2 02-07-2014 07:10 AM
MIDI Editor should hide notes note in clip melino Pro Tools 10 0 06-30-2012 02:36 PM
Changing the midi note duration rbon MIDI 5 05-13-2008 03:11 AM
Changing the size of Midi notes in 'note' mode Violet MIDI 1 11-02-2007 07:05 AM
Changing MIDI Note Duration - Need Help Please JCWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-20-2007 09:47 AM
