Old 09-16-2021, 10:22 AM
emf1138 emf1138 is offline
Default Layout Soft Key macro not working
Am I doing this wrong?
Want to create a soft key macro to show a specific set of VCAs in R-spill (17-24). At the same time I want it to recall a specific memory locator to show/hide tracks on 1-16. It recalls the layout just fine, but the MEM LOC does not get triggered.
Soft key editor:
-ADD
-SURFACE>Titles>Layout recall> *CHOSEN LAYOUT*
-ADD
-EUCON>Project>Mem Loc>*CHOSEN MEM LOC*
PT 2021.6
Eucon 2021.6.1.7
Eric Freeman, CAS
Sound Supervisor/Re-Recording Mixer
Disney TV Animation
IMDB
LinkedIn
Old 09-16-2021, 11:09 AM
creativecontrol's Avatar
Default Re: Layout Soft Key macro not working
Working here. Add a little delay.
Click on one of your function blocks > Options > Initial Delay (I started with 10ms).
(Haven't tested the order but I put EUCON first then Surface.)
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 09-16-2021, 11:10 AM
its2loud its2loud is offline
Why not just create a layout containing all of the above on those dedicated tracks. The VCA’s on 17-24, everything else in 1-16?
Is this on S6? S3?
You might need a “pause” in the soft key commands between Layout recall and a memory recall
Old 09-16-2021, 11:27 AM
Jeff
Tried 10 ms and 20ms on both blocks separately and it didn't work. I swapped blocks to have EUCON first then SURFACE, didn't work.
Eric Freeman, CAS
Disney TV Animation
IMDB
LinkedIn
Old 09-16-2021, 11:29 AM
Is this on S6? S3?
I'm regularly adding/subtracting tracks and auxes to MEM LOC snapshots. Easier for me to update those rather than updating a eucon layout. I'm happy to learn if there's a way to just as quickly update a layout.
Eric Freeman, CAS
Disney TV Animation
IMDB
LinkedIn
Old 09-16-2021, 11:59 AM
Are you getting any LED feedback from the Soft Keys when you press them? If not, you may want to try quitting WSControl and relaunch it.
Track Folders is another alternative to structuring elements within Layouts or VCA Masters.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 09-16-2021, 01:44 PM
No, no feedback, nothing. No response from button when I have multiple blocks. I remove 1 block and the soft key will function. I rebooted WSControl and it didn't fix it.
Eric Freeman, CAS
Disney TV Animation
IMDB
LinkedIn
Old 09-16-2021, 01:57 PM
It sounds like there may be some other reports of these chains of EUCON + Surface functions falling down. Can you please log a case -> and send me the case number so we can get this squashed? Thanks much.
https://avid.secure.force.com/pkb/ar...-Case-Creation
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
S6 soft key/macro timing Geoff_Mitchell Avid S4/S6 2 06-14-2021 10:04 AM
Macro Shortcuts not working in Mix window. Rooxii Pro Tools 2020 6 11-10-2020 10:35 AM
spilled layout changes display layout kava Avid S4/S6 5 09-05-2018 12:42 AM
Soft Keys 9-16 not working. J-S-Q Avid S1, S3, Dock and Control App 2 05-19-2015 12:51 AM
EuControl 3.1 Macro Keystroke commands not working jtwinpcola Artist Series 4 01-09-2014 05:28 AM
