Setting LE as slave to receive MTC
I want to use LE as a slave and set it up to receive MTC. I have a BR1600CD which I bought for a No Latency solution. The BR supports MTC as both master and/or slave. I want to use the BR to signal LE to follow the MTC signals coming from the BR. I have been able to get LE to send MTC, (by setting up in the Setup /Session menu section,) but I need LE to RECEIVE MTC and act as the SLAVE. Has any body out here had any success with controlling LE using MTC.
If I set LE for MMC I can operate the LE transport from the BR. The BR also supports MMC - but there is no tempo synch and that's the whole reason I want to do this. My best hope so far is to record a synch track on the BR (which I have done.) This synch track records all the MTC info as it comes out of LE when the MIDI track is played. From there I should be able to play the recorded synch track on the BR, and as I do so, MTC info comes out of the BR and is fed into LE. I have a MIDISPORT USB-MIDI converter and the LED indicators on it light up correctly to show that MIDI is being transmitted. I just think that the MTC coming out of the BR when I'm playing the synch track, is not being received by LE (the LE transport won't start when I hit play on the BR- which it should.) Therefore my assumption is that LE is not set up as a SLAVE to receive MTC. I've looked and looked, but i can't see any settings in LE that talk about slaving with MTC. There is one setting in peripherals that says "alow control of Pro Tools via MMC" but MMC doesn't synch the tempos. |
Re: Setting LE as slave to receive MTC
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
Hi Mykhal C,
Thanks for that link. I'll give it another whirl. |
should be close given the BOSS/Roland connect
Help setting up drum machine as MIDI slave | cometsincaves | macOS | 4 | 08-06-2011 08:31 PM |
Why did I receive 7.3.1 and now what?? | BmoreBest | Pro Tools M-Powered (Win) | 4 | 04-13-2008 02:20 AM |
korg d1600 being slave a slave to pro tools | sbag | MIDI | 0 | 04-12-2007 06:50 AM |
just receive a free SSC... | deeartis7 | Digidesign Hardware & Software | 2 | 10-26-2001 10:09 AM |
When Will I receive the PT 5 CD? | Dog BBQ | General Discussion | 0 | 12-29-1999 11:50 AM |
