Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 12-17-2021, 05:15 AM
peterbrookes peterbrookes is offline
Default I can't change the input tab
Hi.
I've reset the I/Oa to default, but can't get the input tabs to change to 'input" or "bus"
I am running my projects with Focusrite and an external drive.
It just seems to be on some projects and not all.
I have recently started using an M-Audio Oxygen, but don't think this should impact my audio.
Any help welcome.
Old 12-17-2021, 07:18 AM
Ben Jenssen's Avatar
Default Re: I can't change the input tab
Help Us Help You
Old 12-19-2021, 02:12 PM
Tweakhead Tweakhead is offline
Playback Engine ?
Old 12-19-2021, 02:35 PM
^^ exactly.
Most likely cause on a Mac (like you are using) is Pro Tools has selected Built-In Output or similar as your playback engine and it does not have any inputs for you to choose. If so it's doing exactly what is expected.
Can't change Input on Audio peterbrookes Pro Tools 2018 2 06-02-2019 04:15 PM
Change the input and keep the output? CalebT Pro Tools | Intro Discussion 6 10-24-2018 12:21 AM
Can't change input assignments in PT 11.3.0 HD SteveGarman Pro Tools 11 5 07-14-2015 02:28 PM
Change default input? Tom Case 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-06-2009 07:43 PM
no input signal when I change from +4 to -10 gw sound Pro Tools TDM Systems (Mac) 2 08-01-2005 08:18 PM
