Old 09-18-2022, 12:13 PM
Randall-T Randall-T is offline
Default MIDI Bug w/ Maschine Plugin
I feel I have discovered a bug (as I have not had this issue in the past). I have NI Maschine loaded as a Plugin (v.2.15.2 r2) in PT 2022.07.
When I use the Copy MIDI tool (which allows me to copy a Maschine Pattern to PT as MIDI via drag/drop), it appears to work fine EXCEPT I cannot select/edit the MIDI notes normally. This is true in both the Edit Screen, MIDI Editor Screen, and Notation Screen. Event Editor seems OK.
When I click on the notes they do nothing...no select...no sound.
When I double-click a note, it deletes the note (so not 100% broken).
I can lasso several notes at once, they appear to be NOT selected, but if I hit delete, it will delete those notes.
I can select all the MIDI in that track, Ctrl-X it, then Ctrl-V it in the same place, it all works normally again.
It feels like something a little "extra" is coming in with that drag/drop...
Randall-T Productions
Old 09-19-2022, 04:28 AM
dominicperry dominicperry is offline
Default Re: MIDI Bug w/ Maschine Plugin
Have you looked at any of the recent midi bugs threads on the forum?
Start here:
https://duc.avid.com/showthread.php?t=420833
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
NI Maschine Studio Not recording Midi to Pro Tools 12 as a plugin Michael_Knight AAX Plug-ins 4 10-15-2019 01:34 AM
Increase Maschine 2-AAX plugin window size jandereg AAX Plug-ins 0 02-16-2017 09:03 AM
NI Maschine 2.0 Listed as Unauthorized plugin in Pro Tools 10 hellojoshgraham AAX Plug-ins 2 05-28-2014 04:38 AM
Can't get Maschine 2 as plugin for PTExpress Mbot2014 AAX Plug-ins 4 03-22-2014 05:52 AM
Maschine RTAS plugin Mac OSX jonathan.osborne MIDI 0 02-18-2012 06:15 AM
