Old 09-03-2022, 08:18 PM
justjohnmusic99 justjohnmusic99 is offline
Default Can't assign Outputs for Multiband Spliltter plugin
I can't find the option to assign the 4 outs for the plugin Multiband Splitter. The only thing I seem to be able to do in the plugin, is turn off and on the 4 channels.
I setup a Stereo Aux input and put the plugin on that. Then made 4 more Mono aux tracks for the Splitter Outs. But when I to go assign the puts for Splitter, there are no options in the menu. It's suppose to be able to Split up the four bands.
Any insight on this would be Greatly Appreciated!
Old 09-03-2022, 09:56 PM
Default Re: Can't assign Outputs for Multiband Spliltter plugin
This works fine if you work with the plugin on mono tracks and use the multichannel plugin (but not the multi-mono) plugin on stereo tracks.
No options in what window?
You select the track input in the Aux or audio track as a plugin input, there is nothing in the plugin GUI. See the attached screenshot. This is just like many multi-output VIs etc.
All described in the Plugin User Guide. https://resources.avid.com/SupportFi...ide_2018.1.pdf
Multi-mono offers the plugin outputs as greyed out on the track input>plugin selector, I am not sure why, that may be a bug.
Please follow the DUC guidelines and don't post the same question to multiple threads. That just wastes other people's time.
File Type: jpg Screen Shot 2022-09-03 at 9.50.55 PM.jpg (21.3 KB, 0 views)
Old 09-04-2022, 12:52 PM
Hi Darryl,
Thank you so much for all the info. I apologize for the deuplicate. That was an accident. Anyway, I also apologize for oy ignorance for this lugin. It was a a bit confusing. But your information and the link to the Plugins user manuals has helped me imensley! THank you!
Old 09-04-2022, 02:00 PM
Originally Posted by justjohnmusic99 View Post
Hi Darryl,
No problem. Once you see this for the first time you won't forget how this works. I remember being *absolutely* confused with my first multi-output VI.
And the plugin guide seems frequently overlooked, few folks seem to know it exists. Avid do have the plugin guide listed on the Doc page (https://avid.secure.force.com/pkb/ar...-Documentation) , but I wish they would expand that into a table listing like the other doc files so it's not so easy to overlook.
HTML code is On
Can't assign Kontakt outputs mikedocy Virtual Instruments 0 12-20-2015 04:32 PM
Assign outputs odd problem PTPerson ProControl, Control|24, Command|8 0 11-16-2011 11:30 PM
how to assign additional outputs? musicmixer04 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-12-2006 01:09 AM
Can I assign one track to multi outputs (digi002r) Ralph K 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-06-2004 06:54 PM
Assign multiple outputs from a Midi Track Antonio Tarantino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-11-2003 05:17 PM
