Old 08-04-2022, 06:15 AM
Default Tracktion f'em synth
Audio Deluxe has this synth on sale for $29 (normally $179) which would normally be a no-brainer. Problem is there's no MIDI mapping within the plugin although Wolfram Franke in a KVR thread says it's on the to-do list http://https://www.kvraudio.com/foru...2411&start=120
Quoting his response from a year ago:
"1b. MIDI mapping in general: this is on the todo list for a future update. But in most hosts you should be able to find a MIDI CC > plugin parameter mapping so not all is lost."
Problem is trying to use PT's automation assign shows there's almost nothing that's automatable - most of the left hand side of the parameter assign window is blank. I can't find anything to map - specifically I'm looking for overall output level to map to cc7 so I can use my volume pedal. I could live with PT's automation assign IF it was there.
The question I have is:
Has anybody here used this synth and how'd you deal with the lack of mappable/assignable controls like master output volume. I'd like to be able to use the volume pedal connected to my Motif 7.
Jack
QAPLA!
Digi 001 issues with Tracktion 2.1 Yig 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-06-2007 10:54 AM
PTLE VS. Tracktion: PTLE so slow to load plugins! rossscarbro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-25-2005 09:38 PM
anyone tried tracktion? work with PT? samrisio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 01-06-2005 08:17 AM
Mackie Tracktion-Free Severe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-22-2004 09:04 AM
Soft synth vs Hard synth! Reason, Pro 52, V Statio Jak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 11-08-2003 10:51 AM
