Are you a PT 'VSO' Genius......?
Got a tricky one here....!! Im using the 'VSO' function in the session set up window to slow down my PT session. Using this function you can only go down to -3.00 semitones or 83 %. So my question is; is there a way to apply this same function to a session but to go lower than the 'VSO' allows - ie lower that -3.00 semitones. Any help would be great as i am working on a job and they are killing me on this one!!! Thanks James |
Re: Are you a PT 'VSO' Genius......?
you may want to make a Session Copy
In that COPY - Switch all tracks from samples to Ticks - Elastic Enable Tracks in VariSpeed Mode - Lower the session tempo, to the desired VSO drop - Render the tracks by "Committing EA" or Consolidating the audio.
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
Thanks David,
Does this allow me to go lower that the 'vso' slider bar. Ta j |
AFAIK you can go "Right Down" - Rather then the VSO settings in Session Setup, effecting the Clock, with external Sync perif's - the Elastic Audio VariSpeed is all done internally.
"Seeming" to "Slow down the playback head" similar to a "Shift+Playback" I personally have "Played with" slowing a session with all EA VariSpeed tracks in the session, but have never "Printed" (Committed / consolidated them) and taken the tracks / session out of VariSpeed Mode. You'll get further in experience, then I have with this - Let us know how it works. From my "Playing around" I was trying to get a "Tape Spin Down" effect, like we could get from serato, or other AS plugins, and I found that the tempo changes were more of a "Stepped" effect, then a linear one... so I abandoned ship.
and I should also mention I did this for movie trailer music score and it worked great.
Thanks O.G. that's a good tip, I'll play with that again.
QQ for a midi genius | albee1952 | MIDI | 7 | 06-22-2012 05:32 PM |
expression-less (filo, need your genius please) | bananachan | MIDI | 2 | 04-14-2007 11:53 AM |
This is pure genius!!! | K.B. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 30 | 12-17-2004 10:05 PM |
This is PURE GENIUS! | da BaSsTaRd! | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-20-2004 08:33 AM |
Genius of Sony | TLarvenz | Pro Tools TDM Systems (Mac) | 3 | 12-04-2003 06:24 AM |
