2DSP 96voice, Delay Compensation, Pre-roll Problem
My computer is G5 2G Dual with 2.5G ram, OS is 10.3.8 The Protools system is HD3(the old one, not accel) with 192I/O. The Protools software is 6.9.1 Problem 1: When I use 1 DSP 48 voice, there is no problem. But when I use more than one DSP (2 DSP 96 voice; 3 DSP 96 voice) and use excessive plugins (like 16 voice of LinEQ),the next track i apply plugin will have a loud loud steady white noise thing. The noise is always louder than original signal on that track!!!! I tried swapping the order of the process cards, doesn't help. The problem doesn't apply only to LinEQ. It also happens on GML EQ and some other plugins. I tried unplug one process card and the noise appears at around the 20th to 24th voice of track even if i didn't apply any plugin on any track. and the noise is like a digital loop which glows louder after a few seconds. Problem 2: Delay Compensation is not working properly. When I applied those plugins with long latency, with Delay Compensation on, the track suddenly out of sync. Even worse than without Delay Compensation. Problem 3: When I use Pre-roll function during tracking, that track is suddenly out of sync. So I must manually Quick Punch every time..... Similar things happen when I apply Audio-Suite on a track e.g pitch shifting a vocal, if Pre-roll is on, the processed audio is often miss placed(mostly ahead of the original timing). that's extremely weird!!!!!! DigiTech please help!!!!~~~!!!! My clients keep on complaining about this!!!!! Thanks Soloan |
Problem with automatic delay compensation | surstromming | Pro Tools 11 | 17 | 10-29-2013 11:36 PM |
Problem with delay compensation | juh | macOS | 10 | 04-15-2013 06:04 PM |
Delay compensation problem in PT10 | corym | Post - Surround - Video | 6 | 05-04-2012 03:37 AM |
PT10: Problem with Delay compensation? | saved69 | Pro Tools 10 | 1 | 10-30-2011 02:55 PM |
My problem with Pro Tools HD 7.2 delay compensation | jacko | Pro Tools TDM Systems (Mac) | 5 | 03-19-2007 12:10 PM |
