Old 09-27-2021, 10:11 PM
BasilF BasilF is offline
Default A Strange Problem
Let's say that I create a tune. I work on it. I open up a different track to work things out and then bounce it to the main track. What has started to happen is that the bounced track is three 8th notes behind. Adjusting it is no problem but there's more. In the secondary track, if I bounce it to another track and then bounce that one to the main tune, there is no issue. It shows as being on the 1. I've been using PT since 2005. This is a new one. Any ideas?
Old 09-27-2021, 11:34 PM
Ben Jenssen's Avatar
Ben Jenssen Ben Jenssen is online now
Default Re: A Strange Problem
I find this very difficult to understand. It might be because of the way you use the word 'track'. Outside PT 'track' is often used for a song; a track on an album. In PT a track is a instrument, midi, audio, or aux track in a session. also; "bounce into the main tune", what do you mean. Could you clarify please?
Life-long audio enthusiast and small studio owner. Retired.
Mac Mini 2018, six-core 3.2gHz i7, 32 gb RAM.
Focusrite Scarlett 6i6 2nd gen, Dynaudio BM6's, Command|8, SSL UC1.
Pro Tools 2020.11.0.157, Mac OS 10.15.7.
Old 09-28-2021, 09:21 AM
Thanks for responding. Yea, "track" is confusing. You boot PT. You create a new project. We'll call it project A. You work on it. There may be something that you want to work out, like a solo or orchestration. For that, you create another project. In that one, when I bounce to the original project, it's off by three 8th notes. Yet, in the secondary project, if I bounce it to another track and then bounce THAT track to the original project, it's perfectly aligned on the 1.
Old 09-28-2021, 09:32 AM
JFreak JFreak is online now
Track is something that has a fader in a mix window. Session is something that has one or more tracks. Project is a session that is stored in the cloud.
Old 09-28-2021, 09:33 AM
OK.
Are you careful that you select exactly the region that you want to bounce, in both bounce procedures? If you are, I'm out of ideas.
(Actually the term 'project' is also a bit of a problem. Of course we all work on projects all the time, but for those who are using Pro Tools First, it could be a cause for confusion, because: Avid, in their wisdom, decided that they would call the two different types of sessions that PTF can have, is called 'project' - it is stored in the cloud, and 'session' - that is stored on your harddisk.)
Old 09-28-2021, 08:39 PM
Robruce Robruce is offline
Track is something that has a fader in a mix window. .... snip
Hmmm... check page 217 of the PT 2019 manual.
"Track" and "channel" are almost interchangeable terms, that's why there is some confusion.
This might be a more precise definition;
A "channel," or channel strip is the thing with the fader, it routes incoming and recorded audio and MIDI to and from a "track".
A channel strip also controls an Aux or Master fader instance.
A "track" is the audio or MIDI itself.
Old 09-28-2021, 09:03 PM
"Channel" is mono input or output. "Channel Strip" is just a marketing name for analog console equivalent of putting EQ and dynamics processing into single plugin.
"Track" also comes from analog world, from the days of us dinosaurs when we recorded audio to magnetic audio tape, thus one "channel" was recorded into a "track" of magnetic data.
Old 09-28-2021, 09:06 PM
Exactly. The track is the data, the channel is the path.
Old 09-28-2021, 09:07 PM
Yes, but my oversimplification of "something that has fader" is the representation of the data. Once you have done recording, you can disable the "channel", as in no input to your track.
Old 09-28-2021, 09:14 PM
Hence the confusion.
Strange GUI problem jeff markham macOS 2 12-15-2015 10:14 AM
A big and Strange problem! SpecTech macOS 0 12-17-2010 01:13 PM
Strange Problem PT 6.9.1 Russ M. Pro Tools TDM Systems (Mac) 1 02-17-2007 06:53 AM
Strange Problem--Please help jessmador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-07-2006 04:39 AM
strange problem lcouri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-22-2001 12:21 AM
