Old 10-12-2012, 10:38 PM
smpkeys smpkeys is offline
Default Easy Drummer crashing 10.3.1
Easy Drummer, version 1.3.1 is crashing Pro Tools 10.3.1 on my system.
It worked fine in 10.2. I installed 10.3.1 as a clean install, after uninstalling 10.2 first.
If open a session file that has an Easy Drummer instance, or if I try to import session data (importing a track that has Easy Drummer on the track), the result is a Pro Tools shut down.
Anyone having this issue? I trashed prefs and repaired permissions with no change.
Below is part of the Error report from OSX:
Process: Pro Tools [255]
Path: /Applications/Avid/*/Pro Tools.app/Contents/MacOS/Pro Tools
Identifier: com.digidesign.ProTools
Version: 10.3.1.36 (10.3.1f36)
Build Info: Unknown-1031036~36
Code Type: X86 (Native)
Parent Process: launchd [121]
Date/Time: 2012-10-13 00:31:59.455 -0500
OS Version: Mac OS X 10.7.4 (11E53)
Report Version: 9
Interval Since Last Report: 817116 sec
Crashes Since Last Report: 5
Per-App Interval Since Last Report: 318624 sec
Per-App Crashes Since Last Report: 4
Anonymous UUID: 0641DE8A-B120-437B-B1BC-5E93EA358E4B
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000e2cd16cd
VM Regions Near 0xe2cd16cd:
CG backing stores 00000000c5582000-00000000c61a4000 [ 12.1M] rw-/rw- SM=SHM
Submap 00000000ffff0000-00000000ffff2000 r-x/r-x process-only submap
Application Specific Information:
objc[255]: garbage collection is OFF
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.toontrack.superior.auezdrummer 0x2625cb95 NewMachOPlugIn + 338373
1 com.toontrack.superior.auezdrummer 0x262b7254 NewMachOPlugIn + 708740
2 com.toontrack.superior.auezdrummer 0x262c8990 NewMachOPlugIn + 780224
3 com.toontrack.superior.auezdrummer 0x262c8bdc NewMachOPlugIn + 780812
4 com.toontrack.superior.auezdrummer 0x2627dfd2 NewMachOPlugIn + 474626
5 com.toontrack.superior.auezdrummer 0x2627d0dd NewMachOPlugIn + 470797
6 com.toontrack.superior.auezdrummer 0x262c70e6 NewMachOPlugIn + 773910
7 com.toontrack.superior.auezdrummer 0x262dbc7d NewMachOPlugIn + 858797
8 com.toontrack.superior.auezdrummer 0x2629ac10 NewMachOPlugIn + 592448
9 com.toontrack.superior.auezdrummer 0x262b5d97 NewMachOPlugIn + 703431
10 com.toontrack.superior.auezdrummer 0x2621637f NewMachOPlugIn + 49583
11 com.toontrack.superior.auezdrummer 0x26208b48 0x26200000 + 35656
12 com.toontrack.superior.auezdrummer 0x262f2f01 NewMachOPlugIn + 953649
13 com.toontrack.superior.auezdrummer 0x262047bb 0x26200000 + 18363
14 com.toontrack.superior.auezdrummer 0x2620663e 0x26200000 + 26174
15 com.digidesign.framework.DAE 0x0c62da34 FicGetApplicationInterface + 43332
16 com.digidesign.framework.DAE 0x0c73e433 FicSetPlugInChunk + 51
17 com.digidesign.framework.ProTools 0x0a238170 MFortressHWBPEntryPoint_exit_mfort6317_ + 8282982
18 com.digidesign.framework.ProTools 0x0a012cac MFortressHWBPEntryPoint_exit_mfort6317_ + 6033058
19 com.digidesign.framework.ProTools 0x0a06598b MFortressHWBPEntryPoint_exit_mfort6317_ + 6372225
20 com.digidesign.framework.ProTools 0x09fed66b MFortressHWBPEntryPoint_exit_mfort6317_ + 5879905
21 com.digidesign.framework.ProTools 0x0a0f5d4b MFortressHWBPEntryPoint_exit_mfort6317_ + 6963009
22 com.digidesign.framework.ProTools 0x0a060ea8 MFortressHWBPEntryPoint_exit_mfort6317_ + 6353054
23 com.digidesign.framework.ProTools 0x0a15fd89 MFortressHWBPEntryPoint_exit_mfort6317_ + 7397247
24 com.digidesign.framework.ProTools 0x0a14556e MFortressHWBPEntryPoint_exit_mfort6317_ + 7288676
25 com.digidesign.framework.ProTools 0x0b243334 MFortressHWBPEntryPoint_exit_mfort6317_ + 25105706
26 com.digidesign.framework.ProTools 0x0ae7dd41 MFortressHWBPEntryPoint_exit_mfort6317_ + 21151543
27 com.digidesign.framework.DFW 0x005955eb TCommandHandler::PerformCommand(TCommand*) + 187
28 com.digidesign.framework.DFW 0x00595f3f TCommand::Process() + 31
29 com.digidesign.framework.ProTools 0x0a8e7a58 MFortressHWBPEntryPoint_exit_mfort6317_ + 15293518
30 com.digidesign.framework.DFW 0x0058b9ea TApplication::ProcessEvent(TEvent*) + 26
31 com.digidesign.framework.DFW 0x0058c300 TApplication::WakeUp() + 64
32 com.digidesign.framework.DFW 0x006f192b TApplication::CreateNewOSApplication(void*, void*, void*) + 667
33 com.apple.HIToolbox 0x9b143dec _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
34 com.apple.HIToolbox 0x9afbf4f3 _ZL23DispatchEventToHandlersP14EventTargetRecP14Op aqueEventRefP14HandlerCallRec + 1602
35 com.apple.HIToolbox 0x9afbe970 _ZL30SendEventToEventTargetInternalP14OpaqueEventR efP20OpaqueEventTargetRefP14HandlerCallRec + 482
36 com.apple.HIToolbox 0x9afbe788 SendEventToEventTargetWithOptions + 75
37 com.apple.HIToolbox 0x9afd43aa _ZL29ToolboxEventDispatcherHandlerP25OpaqueEventHa ndlerCallRefP14OpaqueEventRefPv + 3152
38 com.apple.HIToolbox 0x9afbf9ae _ZL23DispatchEventToHandlersP14EventTargetRecP14Op aqueEventRefP14HandlerCallRec + 2813
39 com.apple.HIToolbox 0x9afbe970 _ZL30SendEventToEventTargetInternalP14OpaqueEventR efP20OpaqueEventTargetRefP14HandlerCallRec + 482
40 com.apple.HIToolbox 0x9afd3755 SendEventToEventTarget + 76
41 com.apple.HIToolbox 0x9b143c38 ToolboxEventDispatcher + 82
42 com.apple.HIToolbox 0x9b143d67 RunApplicationEventLoop + 236
43 com.digidesign.framework.DFW 0x006fae6b DFW_EventLoop::RunApplicationEventLoop() + 11
44 com.digidesign.framework.DFW 0x0058babd TApplication::Run() + 45
45 com.digidesign.framework.ProTools 0x0b45f3d8 MFortressHWBPEntryPoint_exit_mfort6317_ + 27317710
46 com.digidesign.framework.ProTools 0x0b460b59 LaunchProTools + 1305
47 com.digidesign.ProTools 0x0000f317 0x1000 + 58135
48 com.digidesign.ProTools 0x0001041a 0x1000 + 62490
49 com.digidesign.ProTools 0x0000f09d 0x1000 + 57501
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x97ef490a kevent + 10
1 libdispatch.dylib 0x95c83e10 _dispatch_mgr_invoke + 969
2 libdispatch.dylib 0x95c8285f _dispatch_mgr_thread + 53
Thread 2:
0 libsystem_kernel.dylib 0x97ef1c5e semaphore_wait_trap + 10
1 com.digidesign.framework.digitrace 0x013ef98a digitrace_initialize + 10122
2 com.digidesign.framework.digitrace 0x013f40df DigiTraceIsActiveFunc + 1263
3 com.digidesign.framework.digitrace 0x013f4265 DigiTraceIsActiveFunc + 1653
4 com.digidesign.framework.digitrace 0x013f43c1 DigiTraceIsActiveFunc + 2001
5 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335
6 libsystem_c.dylib 0x995b46de thread_start + 34
Thread 3:
0 libsystem_kernel.dylib 0x97ef1c22 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x97ef11f6 mach_msg + 70
2 com.apple.CoreFoundation 0x9042a9da __CFRunLoopServiceMachPort + 170
3 com.apple.CoreFoundation 0x90433b04 __CFRunLoopRun + 1428
4 com.apple.CoreFoundation 0x904331dc CFRunLoopRunSpecific + 332
5 com.apple.CoreFoundation 0x90443f01 CFRunLoopRun + 129
6 com.digidesign.framework.ProTools 0x0b45cf17 MFortressHWBPEntryPoint_exit_mfort6317_ + 27308301
7 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335
8 libsystem_c.dylib 0x995b46de thread_start + 34
Thread 4:
2 com.digidesign.framework.CoreFoundation 0x002522e2 Sys_MachExceptionHandler::Init(bool, int) + 706
3 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335
4 libsystem_c.dylib 0x995b46de thread_start + 34
Thread 5:
6 com.digidesign.framework.DAE 0x0c60b737 FicIsAlive + 983
Thread 6:
0 libsystem_kernel.dylib 0x97ef32de __ioctl + 10
1 com.digidesign.framework.PlatformSupport 0x008c0e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220
2 com.digidesign.framework.PlatformSupport 0x008cb52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492
3 com.digidesign.framework.CoreFoundation 0x0024c7b6 Sys_BlockingTimer:estroy(Sys_BlockingTimer*&) + 886
4 com.digidesign.framework.CoreFoundation 0x002301f0 Sys_RawThreadTimerTask::Exec() + 64
5 com.digidesign.framework.CoreFoundation 0x00230004 Sys_RawThreadTask::Run() + 36
6 com.digidesign.framework.CoreFoundation 0x0024cba4 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68
7 com.digidesign.framework.PlatformSupport 0x008c12a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294
8 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335
9 libsystem_c.dylib 0x995b46de thread_start + 34
Thread 7:
Thread 8:
3 com.digidesign.framework.DAE 0x0c6784b0 FicGetContiguousMemRequirements + 148736
4 com.digidesign.framework.CoreFoundation 0x00230004 Sys_RawThreadTask::Run() + 36
5 com.digidesign.framework.CoreFoundation 0x0024cba4 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68
6 com.digidesign.framework.PlatformSupport 0x008c12a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294
Thread 9:
Thread 10:
0 com.digidesign.framework.DAE 0x0c6d7ffe FWMidiCallback + 316702
1 com.digidesign.framework.DAE 0x0c6d9935 FWMidiCallback + 323157
2 com.digidesign.framework.DAE 0x0c6d9b04 FWMidiCallback + 323620
3 com.digidesign.framework.DAE 0x0c6b433b FWMidiCallback + 170075
4 com.digidesign.framework.DAE 0x0c6b0fd4 FWMidiCallback + 156916
5 com.digidesign.framework.DAE 0x0c6b2576 FWMidiCallback + 162454
6 com.digidesign.framework.DAE 0x0c6b28bb FWMidiCallback + 163291
7 com.digidesign.framework.DAE 0x0c705f42 FWMidiCallback + 504930
8 com.digidesign.framework.PlatformSupport 0x008c12b8 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9315
9 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335
10 libsystem_c.dylib 0x995b46de thread_start + 34
Thread 11:
2 com.digidesign.framework.DAE 0x0c705fa5 FWMidiCallback + 505029
3 com.digidesign.framework.DAE 0x0c6b2693 FWMidiCallback + 162739
4 com.digidesign.framework.DAE 0x0c705f42 FWMidiCallback + 504930
5 com.digidesign.framework.PlatformSupport 0x008c12b8 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9315
6 libsystem_c.dylib 0x995b0ed9 _pthread_start + 335
7 libsystem_c.dylib 0x995b46de thread_start + 34
Thread 12:
2 com.digidesign.framework.DSK 0x0d0f3e72 DSK_ParsedZone::Reset() + 22098
3 com.digidesign.framework.CoreFoundation 0x00230004 Sys_RawThreadTask::Run() + 36
4 com.digidesign.framework.CoreFoundation 0x0024cba4 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68
5 com.digidesign.framework.PlatformSupport 0x008c12a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294
Thread 13:
Thread 14:
Thread 15:
Thread 16:
2 com.digidesign.framework.DSK 0x0d0efd8c DSK_ParsedZone::Reset() + 5484
2010 Mac Pro, 3.46 GHz 6 Core Xeon,32 GB RAM, OSX 10.9.5, PT 12.4, RME Fireface UFX, Command 8, Mytek 8x192, SSD evo on System,Audio&Samples on spinner drives WD SATA 64mb Cache
Old 10-13-2012, 08:58 AM
luken26 luken26 is offline
Default Re: Easy Drummer crashing 10.3.1
I'm don't know about EZ Drummer version 1.3.1 with PT 10.3.1 as I have not updated to that version of Pro Tools to date.
I can say that I am having no problems with EZ Drummer 1.3.1 or Superior Drummer 2.3.0 with PT version 10.3.0.
Then again, I'm on a Windows platform so I'm not sure this helps.
Lou
Mac Pro (2019) with 3.5GHz 8-core Intel Xeon W Processor, 48 GB DDR4 Memory, 1TB SSD
Catalina 10.15.7
Avid Pro Tools Carbon, Eleven Rack (ERXP 2.0.1), Neve Shelford Channel, SSL Fusion Analog processor, Avid S1 Control Surface, Yamaha Montage 7 (also used as a MIDI controller), Korg Prologue 16 and Adam A7X Monitors.
Pro Tools Ultimate 2021.6, Logic Pro, VEP 7, Exponential Audio. Eventide, FabFilter. iZotope, McDSP, MDW, Softube, Sonnox, Soundtoys, Waves.
Old 10-13-2012, 10:24 AM
WernerF WernerF is offline
Many folks are having problems with 10.3.1 that they weren't having with 10.3.0. Don't forget that there is a sticky at the top of all of the Pro Tools 10 forum pages with an Avid alert about one of them. Until they fix a bunch of the issues going back to 10.3.0 is probably the best idea for now.
Old 10-15-2012, 12:43 PM
Thanks guys. The bummer is that 10.3.1 fixed the "white noise at the end of a region when recording" issue for me, but then created this new problem.
I skipped over 10.3.0, maybe I'll install and try that.
Superior Drummer 2.2.1 Crashing davebmetal RTAS & TDM Plug-ins 4 05-06-2013 10:18 AM
Superior Drummer crashing on multi out? necjamc Pro Tools M-Powered (Win) 6 05-09-2010 01:35 AM
EZ Drummer not so easy Ode Man Tips & Tricks 3 02-09-2010 05:33 AM
Superior Drummer 2.2.1 Crashing HD ammaclean Pro Tools TDM Systems (Mac) 3 01-25-2010 09:31 AM
Superior Drummer 2 crashing PT Studio Dweller Pro Tools TDM Systems (Mac) 12 12-23-2008 05:17 AM
