Old 01-09-2011, 11:49 AM
GuyPicks GuyPicks is offline
Default Should I uninstall PT8 before Installing PT9...?
I'm getting ready to install PT9 HD.
Should I uninstall 8 first?
I couldn't Find any docs on this.
Thanks,
Guy
System 1---------------------System 2
MacPro 5,1---------------------------Windows 10
2-CPUs-------------------------------i7-CPU
OS X 10.14--------------------------Pro Tools HD2020.5
PreSonus 1824c --------------------HDX / 192 Analog
Fader Port 16------------------------2-24" monitors
NI S61mkII--------------------------32GB Ram
64GB Ram---------------------------4 internal Drives
5-Glyph Rack Drives----------------Presonus 192 Mobile
2-24" Monitors----------------------Nektar Impact LX88+
Glyph Raid 4------------------------Fader Port 2018
Pro Tools HD2020.5----------------PreSonus ATOM
Studio One 5 Pro--------------------Studio One 5 Pro
Old 01-09-2011, 01:45 PM
Dism Dism is offline
Default Re: Should I uninstall PT8 before Installing PT9...?
Always.
Even safer would be a fresh OS install, first.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 01-09-2011, 02:29 PM
Thanks, I'll do that.
Old 01-09-2011, 02:54 PM
caruso7r caruso7r is offline
This is assuming you have a full installer of PT9 If you only have the updater then you must have a previous version installed in order to upgrade. If you purchased online, you should have both the full installer and the updater, so obviously use the full installer and as DISM said uninstall the previous version.
John
Pro Tools 12.5
Macbook Pro & Windows 7 Ultimate 64 Bit
Old 04-01-2011, 01:46 AM
djmoss djmoss is offline
Can I just use the PT9.02 upgrade from PT8.04?
Old 04-01-2011, 02:38 AM
crizdee's Avatar
crizdee crizdee is offline
NO, you must have PT9 or PT 9.0.1 installed first before using the 9.0.2 update.
only pt9 and pt 9.0.1 are available as full installers at the moment.
I would also trash all prefs first.
Chris
Producer, Engineer,
www.ukmastering.com
Uninstall PT Before installing 10.3.3 RCN Pro Tools TDM Systems (Mac) 10 12-28-2012 07:50 PM
what uninstall before PT 10 installing flautista Pro Tools 10 5 12-11-2011 06:12 AM
Uninstall 8.04 before installing PT9? xpandnz Windows 1 01-31-2011 11:54 PM
Uninstall 7.3 before Installing 7.4? GuyPicks Pro Tools TDM Systems (Mac) 2 01-11-2008 06:42 PM
Uninstall 6.4 before installing 6.7? neonknight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 11-10-2004 01:42 PM
