Old 06-11-2021, 08:18 PM
Dave S. Dave S. is offline
Default Did I buy a used lemon HD I/O?
Solved: always remember to connect your cables correctly after moving stuff around.
I purchased a used AVID HD I/O 8X8X8 about three months ago that is just now giving me problems. My set up was working great until today when all of the record armed tracks in ProTools started producing a continuous clicky popping sound along with a fluctuation of the volume levels almost like a tremolo effect. This was happening on the analog inputs into the HD I/O as well as analog inputs on the Omni itself. When I turn off the HD I/O the problem disappears.
HD I/O sync mode stays on INT. I’ve set the clock source to the Omni in the hardware tab for both units. If I remember correctly I think it is supposed to light up as a “LOOP” because I have the Omni set as the master.
Digitest
Omni HD & HD I/O. Failed (screenshot att.)
Omni HD only. Passed
Cable swap (Omni to HD I/O). Failed with two different cables.
Update HD I/O firmware in Digitest successful. Still failed Digitest.
I didn’t try updating the Omni firmware. Both interfaces were showing they were at the most recent version.
I was wondering if it could just be the AD I/O slot #1 on the HD I/O but since it was causing problems on the HD Omni analog inputs as well I don’t know. Of course this is the first year I didn’t renew my service plan. Murphy’s Law at work. Did I buy a lemon? Anybody have any suggestions for what could be wrong?
Thank you!
File Type: jpg D4A7F62D-8B5E-40BF-983D-D1F076BDECB8.jpg (33.0 KB, 0 views)
Dave
Pro Tools Ultimate 2022.12 / OSX Monterey 12.6.2
Avid HD Omni / HD IO 8x8x8 / HDX Sonnet Echo Express 3
iMac Pro 3GHz, 10 Core, 64 GB
Old 06-12-2021, 11:50 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Did I buy a used lemon HD I/O?
Are all the loopSync cables tight?
Old 06-12-2021, 12:29 PM
DetroitT's Avatar
Hi. You will need in addition to Digilink, 2 BNC cables.
Connect main Omni sync out to HD io Sync in.
Then HD io sync out to Omni sync in. (That is your Loop Sync)
Old 06-12-2021, 12:35 PM
Good God, my brain was fried last night, I removed the loop sync cable when moving the units. Always glad to find an easy fix even if it makes me feel like a dumbass!
Dave
Old 06-12-2021, 12:36 PM
Thank you!
Dave
Old 06-12-2021, 01:29 PM
DetroitT's Avatar
Your welcome.
Lemon Rack Back! robertmonroe Eleven Rack 2 09-20-2011 01:15 PM
Macbook Pro i7 + 003 Rack + ProTools 8 = Big, Big, Lemon thegift 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 10-18-2010 12:48 PM
3 Power Harness Recalls = a lemon ChuckLogan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-07-2005 10:46 PM
Lemon Jelly's new single with interesting 'B' side K.B. General Discussion 8 07-05-2005 04:26 PM
G5/HD2 lemon? cabin7 Pro Tools TDM Systems (Mac) 12 09-27-2004 07:45 PM
