Old 09-22-2003, 06:08 AM
1245 1245 is offline
Default WHY CAN\'T ONE USE NORMAL WAVES WITH PROTOOLS
I purchased Waves before I purchased 002 and when I install waves, it doesn't show in Protools software. Is this a PURE business related issue? It it is, It Sucks. Trying to make to BUCK.
Old 09-22-2003, 06:42 AM
Default Re: WHY CAN\'T ONE USE NORMAL WAVES WITH PROTOOLS
'Normal' Waves? Exactly what version of Waves do you have?
Quad 2.5 G5, 4.5G RAM
Old 09-22-2003, 07:06 AM
where02190 where02190 is offline
If you have the OS9 version you must upgrade for OSX.
Old 09-22-2003, 07:53 AM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
It shows - olnly it installs in thye wrong folder. Move the Waveshell files to Program files - COMMON FILES - Dae - Plug-ins. Start Protools and voila..
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 09-22-2003, 09:23 AM
I have Waves Platinum super bundle. I used it with Sonar, but now I would like to incorporate it to protools.
Old 09-22-2003, 09:25 AM
If that bundle includes PC-RTAS support, it should work (if it's correctly installed.)
Old 09-22-2003, 09:52 AM
Would you please tell how do you correctly install it? I install it in PROGRAM FILES-DIGIDESIGN-DAE-PLUG-INS but when I open protools and go to audiosuite I don't see the plug-ins, neither in the mix window.
The Weed's Avatar
The Weed The Weed is offline
Waves Platinum works here, it's RTAS, and has to be installed as RTAS in the correct folder for PT to see it. If you are using 6.1 with the 002, I believe you need version 4.0 of the Waves.
Cheers,
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 09-22-2003, 10:14 AM
No, I am not using PT 6.1 I am using 5.3.2 and WAVES platinum 3.5
I don't quite get the RTAS version on this.
Thanks for your advises.
Gerson.
Old 09-22-2003, 10:32 AM
bassbuddy bassbuddy is offline
You need to place the plug - ins in the plug in "settings " folder , that lives in the DAE folder, then you should see them .
kenny
my webpage
4 minutes to startup protools-le, is this normal? fson Eleven Rack 25 09-05-2011 08:56 PM
Waves 7 with Protools 7.1 Reb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-12-2009 06:23 AM
What is the diference btw ProTools 8 Educational and the normal version? Mage Pro Tools M-Powered (Mac) 4 09-28-2009 09:34 PM
ProTools HD Hangs During Normal Operations picksail Pro Tools TDM Systems (Mac) 6 04-27-2004 11:28 AM
OS X/Protools 6.01/Waves 4.0 not finding Waves Plug-Ins flashbak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-11-2003 08:02 PM
