Re: Switching an internal HD(with sessions on it) from one pc to another....
Uh oh...we've made this another silly thread, and I've gotta ask something serious...yikes!
(yikes?...where did that come from? Can you imagine someone in normal life who went around saying, 'Yikes!' every time they were in a bad situation? What am I thinking?...) OK, anyway... I'm about to put the HD in MY pc, and I'm not sure which 'ribbon' to hook it to. There is one ribbon going from my mobo to the floppy drive, and there is another ribbon going from mobo to my CDRom drive. Now, I BELIEVE it is the ribbon that goes to my CDRom drive that I would also connect this HD to. Would any of you know for sure?...(yikes... [img]images/icons/grin.gif[/img] ) thanksroy
rh music |
while i do not know for sure, i would believe that your right since the are both drives. however, DO NOT TAKE THIS AS PROFESSIONAL ADVISE
Hi there Roy
Definetly not the floppy drive ribbon. The ribbon you have the cdrom on is your ribbon of choice. However I note from your thread that this drive you are installing was previously a slave on another machine. If I was you I would find your Primary drive for this machine you want to install into and hang your already configured slave off this ide cable not your cdrom. If however your cdrom is currently slaved off the master, then you will need a second ide cable to connect this 3rd device from. Roy.... what and how many devices do you currently have on this 2nd machine and how many ide cables/interfaces (exclude the floppy drive) do you have. regards
Scoobster |
... and be prepared for your drive letters to change around.. you may have to do some manipulation with drives and letter assignment.. which OS are you running?
Rail
somewhere in memphis there is a small cloud of black smoke, a few fried circuts and roy, holding a power ribbon w/ a blackend face and hair standing straight up as he says "ooopss, wrong one"
#16
I think I cracked a rib from laughing too hard. That image is priceless biOforce.. thanks for painting it.
Scoobster |
#17
Thank you so much...
Both the old machine I'm taking it out of, and this new one I'm putting it in, are running XP Pro. Now, in my case (new machine it's going in), in layers, I have it as 1.top-CDRom drive 2.middle-Floppy drive...and 3.bottom-Sys. Hard drive. I also have a 1394 card, in which a 40gb 1394 Ext. firewire drive is plugged. So, would you suggest probably the ribbon from my mobo, to #3., my Sys. drive? Thanks you guys!
rh music |
#18
roy, its like 1:40am and your playing w/ computer guts? come on man, put the ribbon down and back away, everything is gonna be alright, i talked to your wife and she said that your allowed to go to bed now [img]images/icons/grin.gif[/img]
#19
I would suggest hanging the drive you want to put in as a slave off the master. But Roy please make sure that you cdrom has its own ide cable and is not a slave hanging off your master or you'll find that you cdrom won't function when you boot up.
Scoobster |
#20
Thanks Scoobster,
Yes, it(CDRom) is on it's own cable, going straight to the Mobo. So, I believe the right one will be the Sys. drive cable. Man, I really do appreciate the help from all you guys. I feel a lot better about it. [img]images/icons/wink.gif[/img] and Bi0, As a matter of fact, I'm gonna take your advice and hit it... some body here has decided to get on the other pc, so I can't get in it now...and I'm getting sleeepy...sleeeepy..I'm.... (thanks again [img]images/icons/wink.gif[/img] )
rh music |
losing tracks when switching between sessions | Tommy Dunbar | Pro Tools TDM Systems (Mac) | 0 | 03-21-2012 12:13 AM |
sessions and plugins deleted after switching users | hillelkaps | Pro Tools M-Powered (Win) | 0 | 06-07-2010 11:22 PM |
switching sessions - delay on playback? | dopplah | Post - Surround - Video | 0 | 05-20-2009 06:37 AM |
6.9.2 Crashes When Switching Sessions | ronstephens | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-18-2005 10:14 AM |
6.9.2 Crashes When Switching Sessions | ronstephens | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-18-2005 10:10 AM |
