Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 08-31-2021, 05:53 PM
blastula blastula is offline
Default Kontakt instrument Volumes and PT
I'm gathering that setting instrument volume in Kontakt is complicated by Pro Tools sending default midi volume info.
If I move one of the Kontakt Instrument faders, they snap back upon hitting play. Okay, known issue....
I know I can change a setting in Kontakt to stop Kontakt insturments from receiving CC7 (Midi Volume) but then I will not be able to automate volume changes in my mix....
kind of a dealbreaker trade off!
But it seems I'm having success by adjusting the midi volume levels on PT Mix page.
But am noticing that the default values on the Kontakt instrument Volume Sliders are all different...Even if i erase all volume automation in PT Edit window, I still see the varying levels set at Kontakt Instrument volume sliders. I've hit the instruments' wrench icons to see that all the internal volume knobs are set at 0, I zero out the volume faders on the PT Mix Page. But still Kontakt volume sliders are all over the place.
How can I reset them to a standard default value?
Also is there a comprehensive resource on how to deal with Kontakt volume in PT? it's such a basic thing yet so messed up!
Old 08-31-2021, 05:58 PM
Default Re: Kontakt instrument Volumes and PT
By the way, I did also look at the Controller page in Kontatk Instrument Options, and made sure the top of the cc7 range was set to -6, but the volume sliders still default to random values. urrrrgh.
Commit Kontakt Multi instrument yanos Pro Tools 2018 5 05-07-2018 03:00 AM
suggested levels for all MIDI volumes in a Virtual Instrument. aeide Virtual Instruments 7 08-10-2017 04:33 AM
Midi Instrument volumes zbar Windows 4 02-11-2012 08:23 AM
Alicia's Keys Instrument for Kontakt DrFord Virtual Instruments 8 09-06-2010 09:40 AM
MIDI instrument volumes steve61 MIDI 5 05-20-2003 12:46 AM
