Pro Tools HD 7.1cs6 Update
Pro Tools HD 7.1cs6 Updates for Mac OS X and Windows XP
For systems with Pro Tools HD 7.0 or 7.1 Available for download from the Pro Tools CS Updates page: www.digidesign.com/download/cs/ What's Fixed in Pro Tools HD 7.1cs6? In addition to all previous fixes, Pro Tools HD 7.1cs6 for Mac OS X contains the following: Fixed: Under Certain Conditions, Recorded Files Could End Up Earlier on the Timeline than Where They Were Recorded (Item #74487)
Administrator Avid Pro Audio Community |
Re: Pro Tools HD 7.1cs6 Update
thank you for your dedication and hard work.
{added in later} i have to say however that it is amazing to me that as of April 1 and this is NOT april fools only 352 came here to get the link could that few people on the planet have done the upgrade?
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
I have to admit, I'm still waiting for a good old stable version of Pro-Tools...just like the good old days.
I remember telling everyone how Pro-Tools was good because it would never crash. Granted...I use plug-ins from NI, and others, and they are more than likely the problem.... but it just makes me wonder why it would take so long for different plug-in makers to update plug ins to work from one version of pro-tools to the next. We all want more features, but what good are features at the expense of stability? In the future, I'd rather wait for bugs to get fixed before something is released... and asking every plug-in maker to have to update, for what seems like minor changes seens like a bad idea. If the problem is Native Instruments, what's the hold up for compatibility? Wasn't PT 7 release like 5 months ago? Just my 2 cents of frustration for today. |
3 or 4 software crashes and a small amount of work lost today in 7.1cs6 today
bummer lost a few cool edits ran ONYX restarted...crashes still happened
When is Digi Planning on upgrading the firmware on the C-24? It goes offline all the time and its a major PITA.
Rail
So whats the story on the RTAS multiprocessor issues?
are they actually gonna be fixed any time soon? |
--Jeremy |
Yeah, Jeremy's not having any problems, so shut up!....H |
".....complain to NI! Your words are wasted here."
Yeah well this _IS_ partly a Digi problem. From compatibility page (The problem is not just at low buffer sizes, it is most noticable with heavy RTAS use ie VI's) Low Buffer Size/Multi-Processor Issues with Pro Tools 7 on Mac OS X There is a known issue with low hardware buffer sizes and the multiprocessor RTAS engine of Pro Tools 7 (HD, LE, and M-Powered). Specifically at buffer sizes lower than 512, multiprocessor setups of Pro Tools can show a marked INCREASE in CPU utilization as you enable more processors. While dual processor models also exhibit this behavior somewhat, it is more noticeable with 3 or 4 processors enabled on the Power Mac Quad G5. Digidesign is aware of the problem, and is actively working on the issue. We have run a number of tests, and while we continue to investigate a fix, our tests have turned up a few situations where this problem is likely to manifest, and a workaround for those scenarios. At buffer sizes 512 and higher, we recommend you use the maximum number of processors. More processors will give you more cycles to run additional RTAS plug-ins and more tracks with little additional overhead from Pro Tools' management of additional processors. We recommend the following setting for existing or new sessions that require lower buffer sizes: 1. In "Setup/Playback Engine" lower "RTAS Processors" to "2 Processors". 2. If you still see errors, one or more of the following will reduce the CPU utilization below the error threshold: * Make some plug-ins inactive * Make some tracks inactive 3. If errors still occur, follow the same instructions with one processor enabled Once you are mixing, you may use all processors, and restore any inactive tracks/plug-ins. You can then increase the HW buffer size to 512 or higher to prevent errors. We are fully engaged in this investigation and we will update our customers as we have more information. |
Pro Tools LE 7.3.1cs6 Update | Avid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-29-2008 12:35 AM |
Pro Tools LE 7.3.1cs6 Update | Avid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-29-2008 12:21 AM |
Pro Tools HD 7.3.1cs6 Update | Avid | Pro Tools TDM Systems (Win) | 0 | 01-29-2008 12:10 AM |
Pro Tools HD 7.3.1cs6 Update | Avid | Pro Tools TDM Systems (Mac) | 0 | 01-29-2008 12:04 AM |
Pro Tools HD 7.1cs6 Update | Avid | Pro Tools TDM Systems (Win) | 0 | 03-30-2006 03:27 PM |
