Can't Drag Drop Audios OR Not Be In Run as admin
Hey
I recently had to put Pro Tools into Run As Administrator mode because of an error I was getting. AAE Error 13001 was encountered. Not enough orivileges to raise priority of a thread. Bad Installer? - Running as admin sorted this... However Now I can't drag and drop wav files into the edit window If I turn off 'Run as admin' this is supposed to stop it - but it won't load if I don't run as admin. Any ideas please |
Re: Can't Drag Drop Audios OR Not Be In Run as admin
On Windows, it's one or the other. With RAA, use Import Audio.
It might be possible to change the permissions for the PT .exe. You'll need to check the Internet how to do that.
I reinstalled Pro Tools now.
I have a different problem. All my plugins crash the damn program now. Installing them again and now reinstalling Pro Tools once more - I am regretting buying a PC now - my Macbook Pro only had 256gb of space so with using NI Komplete too I couldn't install everything. It didn't give me this hassle though lol |
I would try trashing your preferences.
Before trashing Pro Tools preferences, follow these steps to show hidden folders: Click ‘View’ in your File Explorer window, then check Hidden items above Show/hide 1.) Close Pro Tools. 2.) Hold the Windows key on your keyboard and press R. 3.) When the Run window appears, type %appdata% and press OK. 4.) Open the Avid folder, and delete the Pro Tools folder. 5.) Restart your computer and launch Pro Tools |
Are you referring to when PT launches and scan all your plugins? Is that when it crashes?
What is more relaxing than Music? Pro Tools Carbon for macOS 12.7.4 My HDX for Windows11. Gigabyte Z490 Vision D - BIOS F21b Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1) Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity Bricasti M7 (2) Lexicon PCM96 Neumann KH805 - KH310 Yamaha NS-10M Avantone Mixcubes Grace Design M905 Etc, etc, etc. |
MIDI drag and drop causes instrument track to drop channel | midnightrambler | Pro Tools 2018 | 6 | 06-15-2018 10:01 AM |
Trouble drag&drop files - I don't get what I drag in | Sir Hannes | Post - Surround - Video | 3 | 12-10-2017 07:39 AM |
Drag and Drop | daslicht | Virtual Instruments | 0 | 10-05-2009 10:45 AM |
can´t drag /drag and drop from DigiBase in 7 | jofromabove | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-28-2005 08:04 AM |
BFD Drag and Drop... | proxy | Pro Tools TDM Systems (Mac) | 2 | 06-26-2005 06:17 AM |
