Re: 8.0.3 and 8.0.3cs1 Update Issues
The General Troubleshooting tips are for all or most versions of Protools and are not specific just to one cs update hence are not necessaril included in the update notes. Here on the DUC, these tips have been collected over time and posted into the sticky thread for all to see. It is a common practice nowadays to post information on the web for people to search. One can consider it a waste of time to search for information on the web but that is how things are done with the Internet. From the tone of your posts, it sounds like you don't care to follow those tips. They really are a good collection of tips contributed by many experienced users and Digidesign technical people over time and have helps many over the years. It doesn't address everything, but does cover the most common issues and settings.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
since updating to PT 8.0.3 and cs1 I really have hard times PT crashes at least every hour with error messages: -9019 and -9031 I deleted Digi Setup, updated to OSX 10.5.8, removed all 3rd party plugs from the plugins folder - nothing changed In PT 8.0.1 everything worked find Any help? Mr.O |
Make a "HIDE movie" folder on your video drive, place the movie there and you should be fine to relaunch: PT will flag it as missing, let it search for it automatically and it should open correctly. 8.0.3/cs1 is a shambles (dozens of bugs, glitches, things that don't work anymore, both in LE and HD)-as soon as I went back to 8.0.1 everything went back to normal.. Good luck, Benny. |
I've gone back to 8.0.3. Things are fine. I will update when Digidesign gets it right. It looks like I'm not alone. Paul
Dialogue Editor Apple M1 iMac (2021) 16 GB RAM macOS Monterey 12.6.5 Pro Tools Ultimate 2022.12 UAD Volt 476 |
My point is, I am paid to edit sound, not spend my days reading through mounds of discussion group messages or trying one "might-work" fix after another. From what I can tell by some of the other threads about this update, I just might get this cs to work only to find it crashing on one plug-in after another. I don't have time for that crap. I have work to do. I will stick with PTLE 8.0.3 until I hear news of an update that works. (And yes, I am aware of the fact I am wasting time right now by complaining, so, I'm going back to work.)
#16
Reason 4 does work via ReWire, though I was wondering if you were having as many (-6086) error instances as I have. No matter how high I set my H/W Buffer Size and CPU Usage Limit in the Playback Engine, I am still experiencing MUCH MORE FREQUENT "operating system held off interrupts for too long" errors than I had before PT8. The new "Ignore Errors During Playback" option helps some but not optimally. I'd be very interested to hear your experience with this using Reason 4 in PT8.0.3 via ReWire on your system with twice the RAM than I'm using...
Mac Pro 2x2 quad 2.66GHz Dual-Core Intel Xeon Mac OS X 10.6.2 ProTools LE 8.0.3 4 GB RAM Digi002R w/BLA Sig Mod |
#17
Had the same issue.... Reverted back to 8.0.1 and Leopard. Been waiting for said fix. Good to hear its in the works!
MacBook Pro 2018
Pro Tools Ultimate 2023.9 EuControl 2023.11 Avid Control App 2023.11 HD Native Thunderbolt HD I/O + Omni Avid S1 x 2 |
#18
Good evening DigiTechSupt (Administrator)..How are you? Hope all is well What is the status on resolution to the issue I reported? "I installed\upgraded Pro Tools LE 8.0.3 and 8.0.3cs1 updates on Mac Pro with Mac OS X 10.5.8 installed. I am connected to a Digidesign Digi 002 Rack. After the installation of Pro Tools LE 8.0.3 and 8.0.3cs1, the audio output for the Digidesign HW 002 has a red X and I can not use the Digidesign Digi 002 Rack as an audio playback device for Reason 4.0.1. I would like to also mention that a folder called "CoreMIDIServer.framework" opens in the dock and stays open until I force it closed. I've never had this problem with Pro Tools LE 8.0.1..It started after the installation of updates Pro Tools LE 8.0.3 and 8.0.3cs1" Thanks again for your assistance and I hope a resolution will be coming soon...
Mac Pro Quad-Core Intel Xeon 2.26 GHz 8GB RAM Mac OS X 10.5.8 (9L31a) DIGI RACK 002 PRO TOOLS 8.0.3 |
#19
Having the same issue w/ PT 8.0.3cs1 and Reason 4.0.1
Would love an update on the fix status. |
#20
Any new news regarding the coreMIDIserver bouncing folder issue? Just caught this after upgrading too.
IMPORTANT-NOTE ON 8.0.3cs1 Update! | TheChimp | Eleven Rack | 0 | 02-03-2010 01:28 PM |
8.0.3cs1 update...now PT won't load... | ronwasserman | Pro Tools TDM Systems (Mac) | 8 | 01-22-2010 10:14 AM |
Pro Tools TDM 6.9.3cs1 Update | Avid | Pro Tools TDM Systems (Win) | 16 | 09-21-2005 10:23 AM |
Pro Tools TDM 6.9.3cs1 Update | Avid | Pro Tools TDM Systems (Mac) | 20 | 09-20-2005 08:53 AM |
Pro Tools TDM 6.2.3cs1 Update | Avid | Pro Tools TDM Systems (Mac) | 1 | 03-04-2004 09:30 AM |
