Old 02-22-2002, 01:54 AM
Mt.Everest Mt.Everest is offline
Default Waves 3.2 and Plugin Presets, HELP!
I have been using Waves Plugins for years now and never got the presets to show up. Thus, I forgot about them
Now Id like to try them out, and I cant figure out how to make them show up.
I have Waves 3.2 Authorized and did a full install. When I look in the "Waves Plugins Folder" I can see a folder that says "Plugin Settings" but they do not load in Protools.
I tried moving it to the DAE plugins folder, and also moving the indivdual settings into the root level of the DAE plugins folder. No luck
Can someone enlighten me please? Thanks
MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O
PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8
PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626
•••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!•
Old 02-22-2002, 04:02 AM
marcoustic marcoustic is offline
Default Re: Waves 3.2 and Plugin Presets, HELP!
Hi!
Don´t try to select the presets from the settings menu in the upper left.
Select them via the "load" button right next to the "save" and "waves" button. This should work.
Hope this helps.
Markus
www.marcousticaudio.de
Hypercontrol: Convert plugin build-in presets to pro tools plugin presets headsup macOS 4 12-17-2011 02:28 PM
Plugin Presets - waves ScreaminRick Pro Tools 9 2 09-23-2011 07:21 PM
Keep Loosing all Waves presets from Waves tool bar!! crizdee Pro Tools TDM Systems (Mac) 4 03-12-2010 03:59 PM
Waves plugin presets missing EricWillhelm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-03-2010 07:38 PM
Waves Plugin Presets renamed? gkrueger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-14-2009 12:08 PM
