Old 05-16-2008, 05:44 PM
Loudigi Loudigi is offline
Default Sample rate error during playback?
I'm running Mac OSX on a 2x3 ghz dual core intel mac.
4gb ram and PT 7.4.
I did a voice record using PT HD with a 192 i/o. Recorded at 48/24 wav. All session long the project was perfect. At the end of my session everything went haywire. I went to export some files to mp3 and the next thing I know all my audio files are playing too fast and too high pitched. I haven't figured out what's going on, but it seems like somehow, someway, the session jumped from 44/16 to 48/24 and back again, resulting in the incorrect sample rate playing everything too fast and too high pitched. What could cause this? I've never seen this before and I can't seem to fix it.
Important thing to note is that in my session setup, it's alway set to clock sources as SYNC andd clock reference as video references SD. But for some reason it just changed to Loop Sync. But why/how?
I've played with exporting at different rates to other PT sessions and OMFs and only once did things get fixed. And that is when we brought the session from an OMF to a 44.1/16bit new PT session. But it only worked once and is not repeating to fix the rest of the problem.
Any help out there?
Thanks,
Lou
Old 05-16-2008, 06:06 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Sample rate error during playback?
4gb ram and PT 7.4.
Any help out there?
Thanks,
Lou
Sounds like you changed your clock source during the session or turned off a device that was creating the clock and PT reverted to default etc. Any way, sounds like you've got a 44.1 file running in 48k session or the other way round.
Open a new session and use import session data! i think it now automatically converts the files to the incoming sample rate!! if not then in the import dialog page, there's a sample rate section for incoming files where you can set the source sample rate and the incoming target sample rate.
Chris
Producer, Engineer,
www.ukmastering.com
"The current playback engine does not support a sample rate of 48 KHz" error when tr eyeshow Pro Tools M-Powered (Win) 19 09-09-2015 11:10 AM
Sample rate/playback problems with Mbox3 algerij 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-16-2011 03:48 AM
Sample rate/playback problems with Mbox3 algerij 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-16-2011 03:42 AM
playback sample rate ? jackp Pro Tools TDM Systems (Win) 1 05-29-2009 02:09 PM
How to change sample rate playback on HD /96i/o atpmusic Tips & Tricks 3 03-11-2005 05:54 AM
