Simultaneous TDIF and ADAT into 192 I/O?
Using a Mackie D8B with a TDIF card and an ADAT Card, PT HD with 192 I/O. Can the ADAT optical and the TDIF I/Os be used simultaneously? What will be the clock setting on the board (D8B) and in PT? Which ADAT Optical port will one use? The one on the chassis or the one on the Digital I/O card?
Re: Simultaneous TDIF and ADAT into 192 I/O?
Just bumping this up...
I am pretty sure you can mix and match any stereo pair on the 192 digital card. So you can have any combination of Tdif and light pipe up to a maximum of 8 I/O.
cheers spong |
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Raven:
Can the ADAT optical and the TDIF I/Os be used simultaneously?<HR></BLOCKQUOTE> This may be accomplished by using the ADAT I/O on the enclosure and the TDIF port on the Digital I/O card. However, the enclosure ports do not offer real-time SRC (the ADAT Optical format only supports sample rates up to 48kHz). If you have a need to 'up-sample' your audio from your D8B into Pro Tools for session sample rates of higher than 48kHz, then you will need to add another Digital I/O card in the available expansion bay. <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>What will be the clock setting on the board (D8B) and in PT?<HR></BLOCKQUOTE> -I would have the D8B supply the clock to Pro Tools either with a Word Clock connection or by resolving to the ADAT Optical or TDIF audio signals. Brent |
Hi Brent,
So I can get 8 channels of TDIF I/O and 8 channels of ADAT I/O without SRC, SIMULTANEOUSLY, right? What would be the clock setting on PT? DIgital? And with another Digital I/O card I can get SRC on both ADAT and TDIF (8 channels each)? I am just double checking as I need to confirm this to a client. Thanks |
So I can get 8 channels of TDIF I/O and 8 channels of ADAT I/O without SRC, SIMULTANEOUSLY, right?<HR></BLOCKQUOTE> Correct. <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>What would be the clock setting on PT? DIgital?<HR></BLOCKQUOTE> -Yes. However, I would suggest you running a master clock source that both your ADAT, Tascam, and PT can resolve to (assuming that you are going to be performing synchronized transfers). <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>And with another Digital I/O card I can get SRC on both ADAT and TDIF (8 channels each)?<HR></BLOCKQUOTE> Correct. Brent |
TDIF to ADAT convertors and 192 dropouts | Atwiss | Pro Tools TDM Systems (Mac) | 2 | 04-23-2003 04:32 AM |
TDIF to ADAT for 001/002 | Chence | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-18-2003 06:12 AM |
16 extra channels with optical ADAT TDIF on Digi001 | fa100 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-20-2003 11:52 AM |
Simultaneous TDIF and ADAT into 192 I/O? | Raven | Tips & Tricks | 0 | 03-15-2002 06:07 AM |
Simultaneous Recording PT &ADAT | Llanito | Pro Tools TDM Systems (Mac) | 0 | 11-27-2001 05:07 AM |
