bx_limiter & freeze/commit/bounce; anybody willing to look into this?
Hello everybody,
I've stumbled across quite incredible behavior of bx_limiter and some other Brainworks plugins in regard to freeze, commit and bounce functions. I froze bx_limiter and some other plugins on a drum machine closed hat track in a sparse arrangement and I noticed it's transient is not what it was before the "freeze". Elimination and null tests led me to bx_limiter. Next I created a blank session, imported a single hit of the high hat, and did the exercise again. The same result; committed track doesn't cancel the track with bx_limiter working on line. The same with freeze and even with imported bounced track. I have the latest built of bx_limiter and I've found similar behavior with bx_digital V3 as well. Yes, I have PT 12.7.0 on osx 10.12.5, which is not certified by Avid, but Plugin-Alliance's (PA) tech support team and a friend of mine with PT 12.8.0 on osx 10.12.5 confirmed null test failures too. PA's representative has proposed a workaround that is supposed to be working on his side, but it doesn't work for me. He's also suggested that this may actually be a Pro Tools' problem so I'm posting this here, if anybody would be willing to spend couple of minutes to see if they have an idea about what goes on here. I've tested quite some other manufacturers' plugins and they freeze just fine. Even the latest built of bx_dynEQ works fine (while the previous one didn't). So, below is a Dropbox link with a small .zip file of my test session. If anybody is willing to do it, please, do the following:
If you get the same results as I do, does anybody have an idea, whether there is something in the session itself causing this? I'd really appreciate any suggestions. Thanks, Aljoša. https://www.dropbox.com/s/k87gc6o2px...miter.zip?dl=0 ------------------ iMac 27-inch, 3.2 GHz Intel Core i5 32 GB 1600 MHz DDR3 OS Sierra 10.12.5 PT 12.7.0 UAD Apollo twin duo |
Freeze/Commit displaces clips | alfst28 | Pro Tools 12 | 2 | 07-23-2017 01:52 PM |
Vacuum VI won't Freeze or Commit? | Bushpig | Pro Tools 12 | 8 | 12-24-2016 11:52 PM |
High CPU usage after commit or freeze | YYR123 | Pro Tools 12 | 0 | 07-09-2016 05:13 PM |
Commit and Freeze both cause 100% CPU usage | Steevp | Pro Tools 12 | 2 | 05-20-2016 12:07 AM |
Track commit/freeze | Thenewexhibit | Pro Tools 12 | 2 | 12-23-2015 02:50 PM |
