Old 11-23-2015, 01:41 AM
Sir Hannes Sir Hannes is offline
Default how can I move 2 objects to cursor position while not changing their relativ position
Hi, how can I move two objects to cursor position while not changing their relative timecode-position to each other?
just a graphic:
|________________####
(cursor) <- (ctrl click to object)
goes to:
yeah!
What is not working:
|_________________######
(cursor) <- (ctrl click to 2 objects)
doesn't go to
|_######
any workaround?
Old 11-23-2015, 02:25 AM
Stig Eliassen's Avatar
Default Re: how can I move 2 objects to cursor position while not changing their relativ posi
A couple ways:
- unlink timeline and edit
- place the cursor
- use the Object grabber to select the clips
- hit H (Keyboard commands focus on)
__________________________________
- cut or copy
- hit equal, type in the location, and paste
- drag with Grabber in Relative grid mode to move, or Option+drag to copy
Old 11-23-2015, 03:08 AM
Woooh, thanks, I'll try!
Old 11-23-2015, 03:18 AM
Forgot to mention that you need to Shift+click to select multiple clips, but you probably know this.
Old 11-23-2015, 03:33 AM
midnightrambler midnightrambler is offline
I've got another one:
1. Temporarily group the two clips together (alt-apple-g)
2. control-click to correct place
3. Ungroup the two clips (alt-apple-u)
Old 11-23-2015, 04:10 AM
clausiii's Avatar
clausiii clausiii is offline
Default how can I move 2 objects to cursor position while not changing their relativ ...
Or position the cursor with shift on the two tracks, hit shift+tab so that the free space is highlighted, hit F1 for shuffle mode, hit delete.
But this will move all clips behind also...
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 11-23-2015, 05:09 AM
joachim's Avatar
joachim joachim is offline
- place the cursor
Works also with the Grabber Tool in Time and shift-clicking clips (step3)(at least in PT 11).
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 11-23-2015, 05:17 AM
It does, but like clip grouping, it extends the start/end points on each track selection to match. I don't like to work that way, but there are many ways to Rome.
Old 11-23-2015, 05:22 AM
Meads Meads is offline
Usually I cut those to clips at the start of the upper region, then paste at the cursor position (creating a marker at that position first, if needed).
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 11-23-2015, 06:28 AM
Great, that's my favorite.
Thank you all!
C24 - Can't move cursor don4777 ICON & C|24 5 03-06-2014 04:48 PM
Move cursor by x amount? abt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-07-2014 11:19 AM
Clear selected clips shortcut not working hd 10.3.2 dgoodi22 macOS 7 02-08-2013 04:49 PM
um, How do I move the cursor? will the moor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-10-2005 01:41 PM
Need help bouncing only selected clips Simpson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-22-2005 01:40 PM
