Old 09-19-2011, 04:02 PM
Moneta Moneta is offline
Default Dragging Audio from Desktop into Edit Window doesnt work PT9 LE
As the title says I cannot drag audio into the edit window from anywhere (workspace, desktop, etc) for PT LE v 9.05. Any help would be much appreciated to help solve this problem as it is making my life VERY difficult at the moment. Also on a side note, I can import audio using the import command, just cant drag and drop. (computer specs below)
Master: 2007 Mac Pro Quad 2.66ghz Intel, 11gb RAM, Project Mix I/O, OSX 10.6.8, 3 Hard Drives
Slave: PC 2.8 ghz Nehalem i7 930, 12 Gb RAM, W7 Ultimate 64bit, 5 Hard Drives
PT 9.05 LE, Digital Performer 6.03, Waves Platinum 7r16, EWQLSO Platinum Plus, Komplete 6, KORE 2, Omnisphere, Trillian, SD2, Evolve Mutations 1 & 2, Vienna Ensemble Pro
Old 09-19-2011, 04:17 PM
orsidigital's Avatar
orsidigital orsidigital is offline
Default Re: Dragging Audio from Desktop into Edit Window doesnt work PT9 LE
we have somewhat similiar systems and I just dragged from a finder window to a 9.0.5 session np. maybe close everything and run permission fix using Disk Warrior - better end result than disc utility. also go into yr workspace window and make sure you are dragging from an allowed HD?
Old 09-19-2011, 04:54 PM
Havent used disk warrior to repair permissions, but have used the disk utility. The HD I'm using is set to record so I would imagine that would work right? I also just found out if I wait about a minute, the beachball goes away and the audio imports but its much faster on lesser systems that i've used (only a couple of secs). So on that note PT seems to be running really slow I have the Hardware Buffer set to 1024 and I'm still getting CPU overload messages. Any thoughts on what I can do to solve this problem?
[IMG] code is Off
Accuracy of audio clipping in edit window jefloiseau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 04-25-2010 02:29 AM
edit window doesnt follow timeline ? Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-14-2009 06:42 PM
Replacing audio in the edit window.... Super Seven 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 04-14-2004 10:43 AM
How do you scroll the window with the audio on edit window? fsilano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-01-2001 09:53 AM
loosing audio from edit window need help now thanks ALAN MCKNIGHT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-30-2000 10:10 AM
