Anyone using PT for live concert record?
I would really like to hear from anyone using PT live. I will be using a 48 input (6 x 888) 1 core, 3 farm card system.
Advice? [img]images/icons/smile.gif[/img] |
Re: Anyone using PT for live concert record?
i recorded della reese LIVE with choir and full band every sunday for a year at her church in los angeles
on my old MIX + system would be happy to discuss my experience you can call me if you want the number is at my web site or write me
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
I am using my HD3 system for live recording. Sounds bloody great. I only use 24 tracks normally but no problems so far.
I would definately advise getting a split snake and using all your own preamps though. It can get mighty complicated when you are sharing preamps with the live board. I would also get a separate system to record crowd noise and edit it in afterwards (dat adat etc). This gives you a chance to stop recording every so often to keep the audio files from getting too big. Probably isn't a problem, but I get really paranoid about freezing the computer or power failure etc. If you are using 48 tracks I would assign a ton of Ram to protools, otherwise you will run out during a recording after a couple of hours. I think 500meg is sufficient for about 3 hrs of 44.1 recording for 48 tracks, but experiment. I would also suggest some kind of battery backup power supply.
cheers spong |
Recording Live Concert | Bilnva | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 05-20-2004 04:22 PM |
Live concert off the board? | MarkPresti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 02-05-2004 09:23 AM |
Recording Live Concert | surchur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 05-27-2003 05:03 AM |
Advice for using PT for Live Concert Record | postboy | Pro Tools TDM Systems (Mac) | 4 | 09-19-2002 10:06 AM |
Mastering a live concert | John Link | General Discussion | 12 | 07-09-2002 04:26 PM |
