Old 12-05-2010, 08:39 AM
NoiseRoom's Avatar
NoiseRoom NoiseRoom is offline
Default USB or Power Supply for midi contoller?
I was just wondering if there was any benefit to using a power supply for my keyboards compared to powering it from the usb? Is there any performance slow downs to using the usb? I'm running from a Mac Pro.
Thanks
Noise Room
Old 12-05-2010, 09:49 AM
Default Re: USB or Power Supply for midi contoller?
Thanks
Depends on how much power the keyboard draws and from which USB port on the Mac you hook up to. I understand that not all the ports can supply the same power.
Jack
QAPLA!
Old 12-05-2010, 10:06 AM
SixChurchStreet SixChurchStreet is offline
Default
I think for the most part, any particular unit will either work using only bus power, or it won't. For example, my Korg padKontrol works fine on USB power, but also uses a power supply, which I never use. There's no performance difference using it with the power supply. But if I were to use it on an unpowered hub, or a powered hub with too many devices sucking power from it, I'd use the power supply.
- Sent using Tapatalk.
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4
[IMG] code is Off
Power supply for Midi I/O?? Armando Pro Tools TDM Systems (Mac) 2 01-08-2014 03:03 AM
Would this UPS (Uninterrupted Power Supply) protect and power my gear? D_Japan macOS 4 07-24-2011 04:23 PM
O2R as a MIDI contoller for PT 6.9.2? stinkhorn Pro Tools TDM Systems (Mac) 0 10-31-2005 04:10 AM
Which power supply for MIDI I/O? flymax Pro Tools TDM Systems (Mac) 1 04-12-2004 01:32 PM
MIDI BOXES....What no power supply..an $$ option Seller Pro Tools TDM Systems (Mac) 0 09-05-2002 12:41 AM
