Old 10-26-2008, 08:20 PM
dylanternes dylanternes is offline
Default usb midi contoller hookup to 002 rack
i have a usb powered midi controller (m-audio keyrig-49) how do i hook it up to my 002 rack? it has no midi i/o so i cant hook it up to the rack. i have to hook up the usb from the midi controller to my computer. how do i get pro tools to recognize it? any ideas? any help would be greatly appreciated!!
Old 10-27-2008, 07:20 AM
spkguitar's Avatar
Default Re: usb midi contoller hookup to 002 rack
As long as it is installed properly following the manufacturer's instructions and with the latest drivers from the manufacturer, Pro Tools will recognize the USB device as a MIDI input. The USB connection on USB controllers is the MIDI I/O.
All you need to do is select it as the MIDI input on whatever track you are trying to control.
If it doesn't appear in Pro Tools as a MIDI input, then it isn't installed/working correctly at the operating system level.
Old 10-27-2008, 08:43 PM
i am pretty sure i have it installed properly it seems like a routing problem. my inputs are set to ALL. the mini keyboard on the track works but i cant get the controller to register. it should be so easy i feel like im missing something simple. anyone have a usb midi controller and a 002 rack. thanks for the last post i did need to register my controller but im still having issues.
Old 10-28-2008, 08:58 AM
spkguitar's Avatar
Did you record arm the track?
I have multiple USB controllers and use them with the 002R every day. As long as the drivers are installed properly, and you are setting up the tracks properly (record arm, select "All" or the specific controller as MIDI input, etc), that's all you really need to do.
Old 10-28-2008, 03:08 PM
original_min original_min is offline
Have you enabled it as an input in PT?
In Setup/Midi/Input Devices.
Also check your windows hardware list, if it's there but won't appear in PT try restarting computer with the controller on.
For some reason PT occasionally can't find my M-Audio 88 keyboard unless is on during boot.
Old 10-28-2008, 03:44 PM
SeedGuy SeedGuy is offline
To use USB keyboard controllers, you don't have to do this. This step should be used when using MIDI 'machine control' devices
Old 10-28-2008, 04:14 PM
Well I don't know what to say SeedGuy, except 'you're wrong'.
Go to Pro Tools Setup/ Midi/ Input devices, disable whatever you have and you won't have any midi input.
Old 10-28-2008, 04:49 PM
thanks for the help everyone! it turns out that the usb port i had it plugged into didnt like my m-audio keyrig 49 i called tech support and it wasnt in the game controller and sound devices in device manager so i plugged it in to another usb port and now it works. first i had it plugged into the usb in the back of my tower now its plugged into the front. weird!! thanks again everyone for your advice
Old 10-29-2008, 02:49 AM
Yea, I was thinking about the I/O>Peripherals>MIDI Control tab that a lot of people think they need to set up. My apologies.
Old 10-29-2008, 04:39 AM
Bill_Palmer Bill_Palmer is offline
I had an issue with my keyrig 49 too dude even though apparently it's meant to be "plug and play" - yeah right...
I had to download the driver off the m-audio website and then when prompted via the "found new hardware" wizard, point the wizard to the downloaded driver file. If you let windows just do it's thing, the keyrig will power up via usb but it won't be recognized as a midi input device.
Pro Tools cannot locate Midi Contoller device adigot MIDI 0 04-26-2012 12:19 AM
Subwoofer Hookup - 003 Rack / Yamaha hs Monitors adavici 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-11-2011 07:14 AM
USB or Power Supply for midi contoller? NoiseRoom Pro Tools 9 2 12-05-2010 10:06 AM
O2R as a MIDI contoller for PT 6.9.2? stinkhorn Pro Tools TDM Systems (Mac) 0 10-31-2005 04:10 AM
Best feeling midi contoller saeblee MIDI 5 09-19-2004 07:20 PM
