Old 05-10-2009, 11:58 PM
Default Dangerous touch/latch+trim
Digi, please turn this off:
Select touch/latch+trim mode. Then select "plugin" only in the automation enable window.
When you now grab a fader forgetting that "volume" isn't enabeled Pt will trim the volume of the entire track!
I find this an extremely dangerous "feature" and I want to turn it off.
Frank
PTHDn 2021.7 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 05-11-2009, 12:30 AM
Andy Hay Andy Hay is offline
Default Re: Dangerous touch/latch+trim
+1 I've been burned by this a few times!!
Old 05-11-2009, 01:46 AM
Itīs a nightmare. Thanks to a fellow mixer I keep the undo-que window open all the time to check if and when I might have done this without noticing.
IMO, this "feature" (just like the other one Iīve posted) is a malfunction and should be turned off.
Whatīs the point of turning off "volume" in the automation enable window when it still changes your volume permanently and for the entire session?!
Whatīs the idea behind this?
Old 05-11-2009, 02:22 AM
Ian Palmer Ian Palmer is offline
I'm a bit confused. Why wold you turn off any of the tabs in the automation window? I've been mixing with them all on forever and have never come across a situation that I would need to turn them off.
Is there a shortcut that does this?
Ian Palmer
Sound Designer & Dubbing Mixer
@ianpalmersound
Website
IMDB
Old 05-11-2009, 02:48 AM
Because when I want to use apple-alt-/ to write a static EQ to a selection I disable volume because I donīt want to kick my volume curve.
What I describe of course happens unintentionally. Of course I should turn volume back on after the EQ-thing but sometimes I forget.
So I turn on trim grab a fader thinking that Iīm writing volume but I forgot to turn volume back on.
As a result my whole track is trimmed.
In a way itīs 100% user-error, yes, but this could be prevented if PT didnīt write volume-trims without "volume" being activated in the first place.
Therefor Iīm asking what the idea behind this feature is? Maybe Iīm missing something...
Itīs more a "machine adapting to human"-idea instead of "human adapting to machine" concept Iīm asking for.
Frank.
Old 05-11-2009, 04:25 AM
Vedat's Avatar
Vedat Vedat is online now
Quiet Art Ltd.
If I understand correctly what you are asking Digi is to actually disable Trim feature if the fader is not writing automation.
I reckon it would be better as an option in the preferences to turn it off and on as you like, rather than getting rid of it completely.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
SALE ON NOW. UP TO 60%
Old 05-11-2009, 05:00 AM
No. Iīd like PT to not write ANY volumes (incl. volume trims) when I disable "volume" in the automation enable window.
Right now it changes the volume of the entire track even when "volume" is disabeled, as described above.
To me that seems not logical, and so far I havenīt understood the idea behind the current behavior. But Iīll be more than happy to learn what the benefit of this is, if there is one.
frank.
Old 05-11-2009, 09:52 AM
colinweeks colinweeks is offline
frank:
i think it works that way because whenever you dont have automation on a track, it is essentially in manual mode and any settings become the default setting on the track when automation is turned on... if you have trim automation on a track already, protools will NOT write down the entire track as you say, it only happens if the trim automation playlist is empty... same thing happens with the normal volume automation if there isn't any automation written first.... hope that makes sense.
Old 05-11-2009, 01:28 PM
Postman Postman is offline
Frank,
Behavior was changed in PT8, much improved but not perfect. As you know, in PT7, trim preview values tended to be coalesced when the automation was re-eabled. In PT8 this was changed. Now, you can still audition the trimmed moves (whether by accident or on purpose) when automation is disabled (but trim mode is on), and coalescing does not happen automatically. This means you can throw away the trim value by toggling the trim automation mode off and on, which also resets the trim delta to zero and no harm is done. If you do not toggle the trim mode the trim delta remains, giving you the option to coalesce it if you want it. This is better than having to use undo, at least.
There is still big danger because if you have bumped a trim fader and do not realize it, the fader stays at the bumped value and playback volume continues to be sound "trimmed". Hopefully you will notice it before too long because the next time the automation is coalesced, for any reason, the unintentional bumped value is included. So, it is harder to mess up hours of work but not impossible.
+1 for removing the feature. I am sure it was dreamed up for mixing a song, but it is anti-post. It is still too easy to bump a fader without realizing it. None-zero trim faders can be visually seen but smaller amounts can easily be missed, especially if you are not looking for them, and with 100+ tracks, it is way, way, way too easy to miss a huge bump, especially if that track is not playing at the time (as is so very common in post). You can totally mess up an enormous amount of work with one slip.
Old 05-11-2009, 10:45 PM
cjguitar cjguitar is offline
+1 from me. It's a real PITA!!! Happens to me often (at least once a day).
Chris M. Jacobson, CAS
Re-recording Mixer, Sound Designer
IMDB
HTML code is On
touch switches to latch automatically Nick Camaron Post - Surround - Video 25 01-02-2015 06:50 AM
Touch/Latch mode 003 bassmonsta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-19-2012 09:23 AM
touch vs latch, why and when? DHG MUSIC ICON & C|24 11 06-08-2011 07:49 PM
Touch/Latch - Sends gonzolagonda Pro Tools TDM Systems (Mac) 2 07-12-2007 05:53 PM
Latch or touch and trim beech ICON & C|24 3 10-10-2002 11:15 AM
