Logic 4.8 setup/ audio troubles
I am a new logic user and i am have trouble setting up logic 4.8. i have to press the monitor mode button, on the digi 001 box itself, in to hear the audio. but then i have to press it again to actually record the audio. I think i am like special ed or something. also the same rule of the magic button applies to logic plug-ins. if it is pressed i hear the dry audio (no fx) but when depressed i hear the wet audio. Can somebody help me.
Re: Logic 4.8 setup/ audio troubles
Don't worry... Keep at it.
Although the manual does not state this clearly the first step to setting up logic for use with Digi 001 is to bang you head against the wall for at least 48 hours. After that you will be very pleased. [img]images/icons/wink.gif[/img] |
Check out the FAQ at http://f23.parsimony.net/forum49865/
Also, search your Logic manual for "Software Monitor Mode", it's all explained. Good Luck! |
System setup troubles... | mixboy bob | Pro Tools TDM Systems (Mac) | 0 | 04-11-2010 06:49 PM |
Troubles Busing Audio to Instrument Track | thejimmyjack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-06-2009 03:46 PM |
Recording MIDI over audio troubles | .tel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-05-2006 12:18 PM |
Audio Suite troubles -- Help! | ggillis | General Discussion | 0 | 02-11-2004 01:04 PM |
Logic Setup | laydencee | Pro Tools TDM Systems (Mac) | 1 | 11-01-2003 02:55 PM |
