Avid Omni and Cranborne ADAT and 4 analog IN/OUT
Hi can the Avid Omni connect to a Cranborne ADAT for 8 channels of IN/OUT and still use the 4 analog input and outputs?
Re: Avid Omni and Cranborne ADAT and 4 analog IN/OUT
The Omni only does 8 channels total, so you could do 4 adat and 4 analog, or 8 adat.
You're hard limited to 8 outputs with the omni, but you can bring up any number of inputs in the hardware mixer and route them directly to the monitor path and/or cue output, even if they aren't defined as inputs in your pro tools i/o setup.
I use this to monitor my system audio via spdif, and various adat inputs when I just want to listen to them but not necessarily record. The only (slightly) annoying part is that the hardware mixer setup / controls are in pro tools and not in a separate hardware setup application.
-Evan |
Omni to C24 Analog 7-8 | KGraham045 | ICON & C|24 | 0 | 08-23-2016 07:14 PM |
Avid Omni as a standalone "analog to adat" converter. Is it possible? | Kokos | Pro Tools HDX & HD Native Systems (Win) | 5 | 03-14-2016 07:31 AM |
+4 dBu or -10 dBv analog in Omni | chrisdee | Pro Tools HDX & HD Native Systems (Win) | 2 | 10-07-2012 04:15 PM |
Are Omni Analog ins calibrate-able? | Picture Start | Pro Tools TDM Systems (Mac) | 7 | 10-07-2011 08:07 AM |
01V 18bit analog omni outputs? | east3rdst | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-07-2001 08:26 PM |
