No sound after bounce
I am running Pro Tools 10 on Windows 7 and after I bounce to disk there is no sound and Windows Media Player says it can not play the file. I have checked the settings for output in Pro Tools and have selected exactly the same as what it says the output is for the bounce output. It plays fine while it is bouncing, but after it finishes and I open the file it says windows can not play it and when I try to put it in a Windows Movie Maker video there is no sound at all. I have tried WAV and MP3 format and still the same problem.
I had taken some old cassette tapes and recorded them onto Audacity, then uploaded the audio files into Pro Tools. There were several songs on each file and I took several songs from each one and combined them into one audio mix. They are appearing in Pro Tools still as separate parts instead of one continuous one. Maybe this has something to do with it. If so, how would I get the different audio clips to combine into one? |
Re: No sound after bounce
Double-check the bounce source(IIRC, its on the first window that comes up). I bet its NOT choosing your main outs. Don't know why this happens, but it does every so often.
Not an issue. Just pay attention to the total length and make sure your bounce time includes all of it. BTW, if you highlight a clip(1 of the songs) and hit Ctrl-A, that will highlight all of them. Rolling your Bounce to Disk in this fashion will(SHOULD) bounce the exact total timeline. Alternately, you can process the songs in place with AudioSuite plugins, matching any insert processing, then simply export the files(much faster than a real-time bounce).
BTW, if no one has replied to your duplicate of this post, please go to it, select EDIT and look for the DELETE button(only you can do this).
Did you bounce with 24bit/48kHz ? To make the separate "parts" (regions) to one region: mark the first region , shift-click the last and "consolidate" ( alt+shift+3) |
It's a good idea, if you're bouncing to .wav files, to make them 44.1khz/16 bit since that's the CD Red Book standard. WMP doesn't like 24-bit files one bit. (Pun intended...)
Make sure your outputs are correct in the 'bounce' setup window & DON'T use WMP. Use iTunes. It'll play whatever u bounce...
I bounce (export) all my files @ 32/48 which is what I always track @... {Hey SW} Sent from Da GS3 On'eim...
I bounced it with the output set to the exact output that is being used for the sound and I used 44.1 khz/ 16 bit and mp3 and it still didn't have sound when it was finished bouncing and windows media said it couldn't play it. I have bounced it using every single output setting there is and still the same problem every time.
I got the separate parts combined into one. Thanks. |
1. How the bounced files look like?
2. Do they exist and contain any data? 3. Have you tried to import them back to PT? 4. Have you tried to open them with another program? http://www.videolan.org/vlc/ |
Different sound the second bounce | stickstome2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-15-2005 02:24 PM |
Sound changes after bounce. | BxThree1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-10-2005 07:45 AM |
Why Does Bounce To Disc Sound So Bad? | jjelduce | Pro Tools TDM Systems (Mac) | 12 | 03-27-2001 10:18 AM |
Sound at the end of bounce to disk | stevegalante | Pro Tools TDM Systems (Mac) | 6 | 10-28-2000 07:24 AM |
