Bars & Beats Question on PT 5.2.1
I would like to know if anyone have the same problem i'm having with regions (wave or midi)in bars & beats, The problem is that when I copy a region let's say one beat or one bar, then duplicate the region hundreds of time like having a bars of a kick duplicated util I get 8 minutes or something, I found that the regions starts to get out of the grid on the bars as the time go.This is on midi regions or wave as well, I capture a sapmle perfectly on grid for one bar, but keeps geting out of grid anyway. The remedy I found is copy the bar and then pasted on each bar as I get the 8 minutes or so and works perfect, but It takes a lot of time doing it, if do it duplicating, is faster but I get the problem I already describe.
Does anyone is having the same problem? or is it just bug? or is there a property I didn't adjust? does this happend on PT 6.x? Thanks fo the help!!! [img]images/icons/confused.gif[/img]
Dual 1.25,10.3.3 PT 6.4,OS9.2 PT beta 32 tracks,Digi001,HD's:120&160MB IDE,2 GIG's RAM,(2)19" LCD'S, NS-10M, ALESIS M1 MK2,EMU,FS1R,AMT8. |
Re: Bars & Beats Question on PT 5.2.1
Make sure that under the assumption that your audio file loops perfectly, once highlighted the first time (before the Apple+D bonanza begins), you see the entire region selected in black, filling the entire measure. You may need to zoom in a little, there could be a hairline of air at the very end of your loop, which would otherwise go unnoticed, thus causing a drift after a few measures in. I'm guessing that's the culprit. If so, select your loop as well as the air while in grid mode, then do a 'consolidate region', that should take care of it.
www.myspace.com/krou |
Thanks but it try that too and It keeps doing it.
Then perhaps the loop isn't as perfect as you thought?
I can't think of any other reason...
thanks anyway [img]images/icons/cool.gif[/img]
From the <PT manual:
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
make sure u set tempo in pro tools same as tempo of loop
These is very helpfull, I'm goin to try this to see what happens . [img]images/icons/grin.gif[/img]
Thank you Guys!
Bars/Beats ruler question | Dufo | Windows | 1 | 08-04-2013 07:43 PM |
Bars and Beats | GTTTT | Pro Tools 10 | 4 | 04-05-2013 04:51 AM |
Question on Bars/Beats Ruler | session48 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-15-2006 11:37 AM |
Newbie Question : Inserting Bars:Beats | Muxlow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-01-2003 05:08 PM |
bars and beats.....its off | Mikchek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 02-03-2003 01:47 PM |
