more digilink interfaces than HDX ports
Hello, I have an HDX3 system and currently all 6 HDX card ports are fed from two MTRX digilink chassis ports and four ports from 2 MTRX digilink cards.
I would like to integrate an Aurora n 32 with digiiink card installed into this system. If I added an additional MTRX digilink card, could I use it to connect to the aurora and utilize dadman routing and monitoring? Thanks! -Gideon Last edited by cabbagerock; 09-21-2022 at 11:18 AM. Reason: incredibly confusing use of language |
Re: more digilink interfaces than HDX ports
No, this is not possible. The DigiLink ports on a MTRX device (on the chassis or via expansion cards) need to terminate into an engine card such as HDX, HDN or HDNTB.
best, Jeff |
This is what I would do.
James Richmond https://www.jamesrichmond.com 2019 Mac Pro, 2022 Mac Studio Ultra Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro. Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com Latest Article: Auto-Bounce for Logic Pro Affiliate Links: Auto-Bounce by Tom Salta Dreamhost Web Hosting |
Thanks for the quick response Jeff.
uta: I actually have things configured now as you describe with a Lynx dante card, but I miss the record delay compensation that comes with hdx connection. I'm going to try aurora direct via digilink to hdx with Dante Via software running on top to retain dante routing options and see how it goes. |
You have an MTRX with HDX3 and 2 Digilink expansion cards in the MTRX? That should give you 192 physical IO to HDX. The Lynx connected to the MTRX via Dante will still allow delay compensation- you just have to calculate the different latencies for hardware inserts which is in the MTRX manual. Not sure why Dante Via is needed and it comes with a huge latency penalty.
List of third-party Digilink interfaces? | Matt Hepworth | Pro Tools HDX & HD Native Systems (Mac) | 14 | 11-19-2023 02:49 PM |
Sample accurate digilink interfaces in 2019? | LDS | Pro Tools HDX & HD Native Systems (Mac) | 37 | 11-09-2023 10:55 AM |
Multiple interfaces: ideal Loopsync and Digilink cabling? | Eric Lambert | Pro Tools HDX & HD Native Systems (Mac) | 9 | 09-25-2022 12:06 AM |
Interfaces under Inputs say DigiLink N/A. What's going on? [solved] | Focuret | Pro Tools HDX & HD Native Systems (Mac) | 0 | 03-17-2018 10:23 AM |
Q about using two interfaces into two firewire ports | RegisWhite | macOS | 4 | 03-03-2013 07:07 PM |
