Old 05-17-2021, 05:46 AM
Zergei72 Zergei72 is offline
Default Error Opening Sessions
Hi ...
First things first ... I need a fix for this one ASAP ;
"Could not complete your request because Assertion in "..\ ..\ FF\ Audio\ FF_AudioFile.cpp", line 1092.
(Use the Copy button to copy this message to the clipboard.)."
This has propably been issued before, but I bumped to it just now .
My Projects are on a WD External USB - Disk .
HELP !!!
zergei .
Old 05-19-2021, 05:57 AM
Default Re: Error Opening Sessions
Nowhere near enough info, but here's what I would try:
1-hold the SHIFT key while opening the session(which will make all plugins inactive). If the session opens, you can re-activate plugins.
2-Copy the entire session folder to another drive and try to open from there.
3-create a new blank session(same sample rate and bit depth) and then use the Import Session Data function to import all the tracks(I would do a few at a time as doing all may prompt the same error)
4-Create a new blank session but change the sample rate(if original is 44.1K, make this one 48K or vice versa). Import Session Data and let Pro Tools use SRC(sample rate conversion).
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Error when opening old sessions bensonserr Pro Tools 12 3 12-09-2017 11:26 AM
Error opening sessions. Line 978 Wawili_Sound Pro Tools 11 4 08-06-2014 12:30 PM
Error Message When Opening Sessions Gorbies Pro Tools 11 1 04-23-2014 10:11 PM
DAE Error -9124 while opening OsX Sessions sonnie Windows 4 04-02-2013 06:49 AM
Opening 6.x sessions in 7.3.1 error mr.armadillo Post - Surround - Video 0 01-29-2007 12:26 AM
