#41
Re: Does lighbridge support more than 18IO with PTMP?
Um, OK. If you're tracking live with a Lightbridge you're obviously using external pres so why not pull your input monitor mix from the preamps before the converters? That would be no latency monitoring.
#42
what i meant was that i am not producing the musicians cues anyway, so it doesnt matter...
#43
lets keep this post going, anyone else using this setup yet?
#44
using 3 behringer ada800's for the IO and the lightbridge as interface hooked up to a tascam m-600 console. i have all 32 pres running into the line ins on the behringers then the outputs of the behringers running into the 32 tape returns. its amazing. a 32 in 32 out protools system for about $1,600 |
#45
sometimes i almost feel bad for my freinds with hd
#46
63 post's not bad my man...
http://www.gearfreq.com/forum.php |
#47
i tracked a live show using my alesis hd24 as converters. 24 direct outs of a mackie 32-8 in to the hd24. lightpipe out of the hd24 in to the lightbridge directly in to protools mpowered. recorded a 68min show at 128 samples. no glitches at all...
i then brought the project home, pluged in my 002r in my studio and opened the project in le and have been mixing it the last week... hurray!!! i should add that i am using a macbook pro... |
#48
it's amazing isnt it! so why does digi le stop at 18?
#49
My system is: MacBook Pro 2G/2G 160gb internal (system) 60 gig external sata in USB enclosure. Mac OSX 10.4.10, PT M-Powered 7.3.1 M-Audio Lightbridge |
#50
your problem is probably the usb drive. in spite of the specs of usb 2 vs firewire, firewire is still much faster and much better suited for audio. usb is only half duplex. this means data only flows one direction at a time. picture it as a one way 5 lane highway. this makes usb a great application for backup, but when you are writing to and reading from the same drive, it can cause problems. firewire, on the other hand, is full duplex. it is an eight lane highway, 4 lanes in each direction.
get a firewire drive hope this helps... |
Support Update: Avid Support Codes - Effective July 31, 2010 | Avid | General | 0 | 07-31-2010 11:55 AM |
can i sell PTMP 7.3/7/4 ilok license and still keep PTMP 8.0 license? | edgarbc1 | General Discussion | 0 | 07-17-2010 01:09 PM |
Lightbridge and 18IO | wildplum | Pro Tools M-Powered (Win) | 5 | 08-07-2007 08:43 AM |
OSX 10.4.2 and PTMP.... | Aleatoric | Pro Tools M-Powered (Mac) | 1 | 07-26-2005 01:34 PM |
