Old 08-13-2012, 09:29 PM
Rockman413 Rockman413 is offline
Default What is the 2.00 and whole file in Duplicate(audiosuite)
I often use duplicate to connect different audio regions into one. I found there's whole file 2.00 to the right of the interface. What does this mean? for duplicate function, 2.00 or 0.00 or 60.00 makes any different?
And is there any difference for duplicate & consolidate?
Thanks!
Old 08-13-2012, 10:33 PM
Craig F Craig F is offline
Default Re: What is the 2.00 and whole file in Duplicate(audiosuite)
the 2.00 is handle length
duplicate is only copying clips, not making new audio flies
consolidate makes a new audio file
Thank you,
Craig
Old 08-13-2012, 11:05 PM
Duplicate& consonlidate, which way is more safe for protecing original files?
and would 2.00 or 60.00 be the same result for duplicate?
Old 01-29-2013, 08:14 PM
jamesadam3 jamesadam3 is offline
It used to be that duplicate and consolidate were the same. Duplicate and consolidate both created a new audio file out of whatever region was selected. I did a test back in 2003 or so and found that consolidate seemed to distort the waveform while duplicate made an exact copy so I've always avoided using consolidate. Cut to 2013 and I've recently updated to PT10 and now duplicate seems to function differently and doesn't make a solid audio file out of whatever region (oh I'm sorry...clip) is selected. It adds handles of whatever length you set (2.00 seconds). If you set it to 0.00 then duplicate functions just like consolidate. I haven't repeated the test that I did 10 years ago so I don't know if consolidate is still changing the waveform any...I choose to use duplicate.
How to remove Duplicate AudioSuite plugins teacherman Tips & Tricks 3 02-03-2010 01:51 PM
file management issue - pasting duplicate files dendee Pro Tools TDM Systems (Mac) 1 05-03-2009 03:03 PM
Old versions and duplicate source file names ctl_dir Pro Tools TDM Systems (Mac) 2 01-16-2007 12:49 PM
consolidate or duplicate ( continous file) a track cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 10-03-2006 02:23 PM
can't duplicate/rename file bluemt Pro Tools TDM Systems (Mac) 3 03-13-2001 01:30 PM
