Old 06-22-2006, 08:05 PM
Default \"Item\" - Saving Sessions and Duplicate Names
I am seeing something that I believe qualifies as an "Item" (the term used for things that get fixed in cs releases) with saving sessions. Here are the details:
Problem: When saving a session with v7.1cs8, the user is prompted that a session with that name already exists, even though the new session would have a different name.
Reproducible: Yes,
Steps to reproduce:
1. Open up a session from a version prior to v7.0 that did not have Mac/PC compatibility enforced.
2. Choose to save the session without changing the name.
What should happen: The session should be saved with the same name.
What does happen: The user is prompted that a session with that name already exists and that it will be overwritten.
Why this is an item: All v7 sessions have their names end in .ptf. So if my pre-version 7 session was named "version_6" and I went to save it with v7, it would then be named "version_6.ptf". Pro Tools is not taking this into account when saving sessions as v7 sessions. It appears to be oblivious to the fact that "version_6" and "version_6.ptf" are different names. Please consider addressing this issue (item), since it is, at the crux of the matter, not correct.
If anyone can confirm or refute this, please post a response.
Thanks for reading!
Session Copies - Duplicate Sessions [email protected] 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-12-2010 12:38 PM
saving le sessions for HD therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-03-2007 12:46 PM
Old versions and duplicate source file names ctl_dir Pro Tools TDM Systems (Mac) 2 01-16-2007 12:49 PM
Keyboard shortcuts - duplicate menu item names jeremyroberts Pro Tools TDM Systems (Mac) 0 11-18-2005 02:04 PM
need help saving sessions to cd jasonvorghees 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-15-2001 12:54 AM
