I'm running five PT systems in my business, including the latest, a PT LE 6.9.2 MBox system running on a G4PowerMac with OS X.4 "Tiger". We do a lot of audio for "speaking" machines of various types. This sometimes involves hundreds of little audio files. These all have to be exported and renamed. To save time, I have been using an Apple Script to rename the files.
Problem is, I need to know the original names of the files (i.e. regions) as assigned by ProTools, in the order they appear in a track. This would be easy if the PT AutoRename function named regions in the same order they appear in a track, but it doesn't. It's pretty well useless. Also PT TDM has a nice Export Session as Text function, but PT LE does not. I don't want to spend thousands of dollars to upgrade to TDM just to get this simple function. Is there a simple way of either getting my play list export or making PT LE behave when doing AutoRename? Thanks. - Jim Cline
Jim Cline Timberwolf Press / Timberwolf Productions |
a couple of years ago I came up against almost this exact problem - I am a voiceover and wanted to email out a long list of my voice files in a session to make the producers life easier
check out my website - have a PT VO studio at home and happy to provide some quality VO for you ;-) and the answer from the DUC, and eventually digi, was that PTLE cannot do what I wanted...that feature is crippled in the LE version the only workaround I came up with was Grabbing an image from my PT Edit screen, printing it, and then scanning that in using OCR software...which is a bit insane good luck
www.piersgibbon.com www.soundcloud.com/piersgibbon VOICEOVER - Avalon 737sp/Focusrite Saffire Pro 40/Neumann + Rode inside an Esmono voiceover studio (+ Source Connect, Prima LT, Sonifex TBU, Sonnox plugins) Record: MBP 13 inch mid 2012, 2.9 ghz i7 8gig ram, PT 11, GDrive Professional Ext Hard Drive Backup:15 inch early 2008 MBP, OSX 10.10.2 (+Windows 7 PC running Audio TX isdn and tbu codec) Edit: PT Express 10.3.4 on 13-inch, Late 2010 MacBook Air, OS X 10.10.4 |
Music Cue Sheets via Text Exporting | Karl Kalbaugh | Post - Surround - Video | 2 | 09-12-2012 07:25 AM |
BUG: When exporting as Text PT10 crashes | Frank Kruse | Post - Surround - Video | 2 | 11-01-2011 02:30 PM |
Error: PT Reference Guide v8 pg. 298 Exporting Sessions as Text | Craig F | General Discussion | 0 | 07-06-2009 09:08 PM |
Export Session as Text | cpompili | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-05-2005 03:03 AM |
exporting markers as text? | AdamFrick | Pro Tools TDM Systems (Mac) | 3 | 06-05-2001 06:33 AM |
