Old 05-07-2004, 08:36 PM
Tom Harmon Tom Harmon is offline
Default Remove volune line in edit window?
I put a volume horizontal line on tracks in the edit window... not sure just how.... I think it is a new keyboard command I was trying. But now this dark horiazontal line is on the track. How do I get rid of the line? Thanks... Tom
Old 05-07-2004, 08:58 PM
Super Seven Super Seven is offline
Default Re: Remove volune line in edit window?
on one of the pull down menus under the track name in the edit window...it should list the different views, panning, volume, track etc. Just choose the one you wish.
| AMD 64 3800+ | 2.5GB RAM | 200GB SATA | 80GB FW | 256MB Video | Dual 19" LCDs | XP SP2 | PTLE 7.0cs4 |
Old 05-07-2004, 09:38 PM
The minus key (on the main keyboard) in command focus mode toggles volume automation display.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 05-08-2004, 04:14 AM
Rail
Rail: How do you get in the command focus mode? Thanks .. Tom
Old 05-08-2004, 06:59 AM
Bazzle Bazzle is offline
Command Focus is the little [a-z] button on the left top of the edit screen. Check page 30 of the Reference Guide.
Bazzle
Old 05-08-2004, 12:20 PM
madrock madrock is offline
what rail suggests earlier is correct but for this to work, the black flashing cursor must be present on the tracks you wish to change view.
the easiest way to change views on individual tracks is to hold Ctrl+"Windows Key" and click on the item you wish to display in the track view. in your case, click on the track name to return to waveform view. this applies to anything, including automated plug-in features (except waves, unless you're using a mac)
Vertical line in Edit Window Art4me Windows 1 07-02-2011 08:48 AM
Lighten edit window and thicken the volume automation line Sukram Pro Tools TDM Systems (Mac) 26 12-09-2009 12:18 AM
Grid Line Display in edit window - can't turn this off Sound Editing MunKee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-15-2009 12:02 PM
Help pleaz How to remove automation line cristol 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-05-2009 08:28 PM
Breakpoint move line in edit window:How to disable TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-12-2007 12:36 PM
