Old 12-18-2013, 04:59 AM
Default plugin selection crashing PT11.0.2
Been running into a consistent problem. Say I have a plugin on an insert in an audio track and I have the gui open. If I want to change the plugin to another one via the selector in the plugin's gui PT consistently crashes. Yet no problem if I change the plugin from the track insert bin. Happens with any plugin - Avid or third party. Amount of tracks, old or new session - makes no difference.
Not a showstopper but annoying and makes me thankful that my left hand is permanently crooked into the cmd-s position
Anybody else run into this?
Jack
QAPLA!
Old 12-18-2013, 05:23 AM
Drew Mazurek's Avatar
Default Re: plugin selection crashing PT11.0.2
Does it happen with ONLY the Avid plugins in the plugins folder?
www.drewmazurek.com
Old 12-18-2013, 06:19 AM
Are you saying I should remove non-Avid plugins from the folder? Haven't tried that. And even if it doesn't happen with third party plugs removed that's not a solution. All my plugins are up to date. I guess the only solution would be to not use that selector in the plugin gui? Sort of the old joke:
patient: doctor - it hurts when I do this
doctor: well don't do that
Jack
QAPLA!
Old 12-18-2013, 08:06 AM
Update:
Found the problem - Arturia CS80V2 (10 voice) is the culprit. Removed everything but stock Avid plugs then added things back in one developer at a time, starting with the AIR plugs, and so on. There are two versions of the CS80 plugin - the one causing me problems and what I guess would be called the regular CS80 from Arturia. Don't know exactly what the difference is between the two although I do remember now that this 10 voice version in vst form gave me headaches on my old Win XP/Sonar 8.3.1 system so it looks like the same old hassles are still in the aax version of this plugin.
Jack
QAPLA!
Old 12-18-2013, 08:12 AM
Update:
There you go!! Isolate!! Isolate!! Isolate!!
I wasn't suggesting it as a solution, but part of the diagnostics.
www.drewmazurek.com
Old 12-18-2013, 08:21 AM
Turns out the diagnostics became the solution
I still think it's weird how that you can have a plugin in the folder, not use it in a session, but it still causes a problem in PT. I know it happens but still strange
Jack
QAPLA!
Old 12-18-2013, 08:42 AM
PT loads them into the plugin database at launch. That's why the first launch after an update is longer.
I guess the hooks are set at that point?? Who knows!
www.drewmazurek.com
Old 12-19-2013, 03:27 AM
Stereo Missile Stereo Missile is offline
I have had some stability problems with the Arturia plugins as well, didn't realise they could crash sessions when not actually instanciated though! Will have to try removing some and seeing if that helps stability. I am finding generally with Audio based plugins PT11 is pretty stable, but on bigger sessions with some VI's I am running into random crashes.
Does anyone know how to access the crash logs in PT11? They used to come up in PT10 but in PT11 it just comes up with the 'Send to Avid" screen.
Steve Peach
Stereo Missile Recordings
Creative Director - Red Note Visionary Sounds: http://rednote.com.au
Label: http://www.stereomissile.com/
Music Production / Mixing: http://www.stereomissile.com/musicproducer/
Mastering: http://www.stereomissile.com/mastering/
No more host processor selection in PT11 musicman691 Pro Tools 11 9 02-18-2014 12:32 PM
PT11 bug: Movie doesn't play when there's a selection!!! bennym macOS 1 12-10-2013 09:08 AM
PT11 installer crashing MAC IvanP Pro Tools 11 5 08-28-2013 07:37 AM
Midi Quantize Selection Bug Still Present in PT11 BEN6732 Pro Tools 11 3 06-24-2013 09:36 PM
Still can't demo Upgrade plugin selection ? Tom Mix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-16-2005 11:16 PM
