Laying out mixes on a console
Please excuse my ignorance! I was wondering how you go about laying out mixes from pro tools onto a console. I am using Pro Tools 9.0.5 thru an MBox Pro 3rd gen and I have a Soundcraft EFX12 mixing desk. Can I do this? Or what equipment is required if I can't? Thank you in anticipation of your advice! Jamie |
Re: Laying out mixes on a console
You would need an interface that has enough outputs to fit your console inputs and that interface would need enough inputs to receive the signal from the mixer + the main out. You would also need a patch bay so that you can do the necessary routing. The patch bay will have to be set to full normal so that when you insert your xlr or trs cable it will break the signal coming from your daw to the mixer and allow you to feed the mixer with what ever you are recording.
You want your master fader on the console to be sent back into pro tools so that you can record back in pro tools the mix you are doing on the console. If you find this too confusing you might want to consider getting a controller instead, that will enable you to control pro tools and mix with the provided faders of the controller. At the moment I wouldn't recommend the artist series because of the bug in the eucon 3 drivers that prevents them from working, and in some cases reverting back to 2.7.1 doesn't help. The Behringer B-Control Fader BCF2000 is a good low cost alternative, there's the mackie control universal pro which is more expensive, but it gives you a better control of pro tool than the Behringer. There are other options but they all get more expensive with the more options they have. |
What he said.
In your situation, it wouldn't be worth bothering with, because you have so few outputs on the Mbox Pro. You need two for your monitors, so that leaves you with only 4 mono outputs (or 2 stereo pairs). If it's just the idea of using faders, then look into the suggestions about control surfaces. |
Looks nice smaller scale that the raven and the price is smaller also
I read about it but have yet to see it. I know the Raven is too much money, and Mac-only(and after sitting at one for 30 minutes, I'm not so sure I really want that one...too much arm reaching.....). If the MT1 works with Windows, it could be a serious contender for my cash Someone else just posted a pick of their setup using a pair of Acer touchscreens, and that looks very interesting(and lots cheaper).
Yeah they did look nice I saw them
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I9 14900k Win 10 |
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Are you looking for just Pro Tools fader control? Plugin control or other control? (bzzzzt, sorry can't do any of those). Access to mic preamps/line level inputs from the Soundcraft? Access to on board effects from the Soundcraft? recording the mixed live output of the soundcraft like the Mbox was a tape machine? Routing Mbox outputs through the soundcraft and using it as an outboard mixer (I doubt you would with that unit, but its a real thing with many analog consoles) etc. The Soundcraft is not a HUI console, its a live mixer, so can't remote control the faders in Pro Tools. Which is what my guess is you are after. It is likely the most productive thing you can do is not to waste time setting up and learning to use any controller and just use the mouse. Darryl |
Laying to DIGIBETA deck with 002 or 003 | senorsensor | Post - Surround - Video | 14 | 09-07-2010 03:58 PM |
Laying Up FX On MBox and sending OMF to HD | jdiprofio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-17-2010 04:40 PM |
anybody got a LE 6.0 disc laying around? | soulboy01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 10-01-2008 08:27 AM |
Laying back to HDW F-500 | bryston | Post - Surround - Video | 12 | 01-08-2007 12:13 PM |
Laying Back Mixes to a DA88 WTF? | vze24x2x | Post - Surround - Video | 11 | 05-29-2004 04:14 PM |
