Constant CPU Overload!!! Really annoying!! Help!!
Hi! I have a powermac G5 2.3 ghz dual core processor and 6.5 GB of RAM running Pro Tools LE 7.4 and I get CPU Overloads like CONSTANTLY and it sucks!!! What can I do to get rid of this?? I know my computer can handle this or at least it should be able to...
Re: Constant CPU Overload!!! Really annoying!! Help!!
We need way more info, read the help us help you sticky.
If your using VI's try reducing cpu cores. Make sure all of your plugs are fully compatible with Pro Tools 8.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
Where's the help us help you sticky??
At the bottom of the top of the first page of this forum.
OSX10.6.8, 1st gen Power Mac, PT8.0.5, Mbox2 |
Check for incompatible plugins. Also check if there are some plugins both active or deactivated that no longer is in your plugin folder.
Are you opening a session created in another version of PT ? |
Have you tried the Tech Support Folder ?
http://www.digidesign.com/index.cfm?...4&itemid=25974 And of course Genreal Troubleshooting : http://duc.digidesign.com/showthread.php?t=54888 |
Buffer overload -6085 error constant | mikesasa75 | Pro Tools 10 | 11 | 02-22-2013 05:58 PM |
constant CPU error overload!!! | clintusmaximus | macOS | 1 | 12-06-2012 04:17 PM |
Constant CPU Overload and DAE 35 Error | AlissaAudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-20-2012 03:49 PM |
constant CPU Overload and cannot play nor record | franklebel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 09-15-2010 02:37 AM |
Constant CPU overload errors!!! | maxxdog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-09-2010 10:27 PM |
