Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 11-06-2021, 10:54 AM
dominicperry dominicperry is offline
Default Re: Q regarding how to connect TC Clarity M
Originally Posted by digiot View Post
Appreciate the info. Can you clarify if you can send SPDIF to say a Clarity but still able to receive ADAT on the inputs!?
From the updated manual:
"Optical In Format (Detected)
Pro Tools | Carbon automatically detects the digital format of the incoming signal on optical ports 1 and 2.(labeled ADAT In 1 and 2 on the back panel). The detected format is displayed for each port: ADAT, S/PDIF, or N/A.
Optical Out Format
Pro Tools | Carbon provides two pairs of optical in and out ports (labeled ADAT Out 1 and 2 on the back panel). The Optical I/O page of the Hardware Setup lets you set the digital format of each output port to either ADAT or Optical S/PDIF. When set to ADAT, each port provides up to 8 channels of digital audio depending on the sample rate. When set to Optical S/PDIF, each port provides up to 2 channels of digital audio up to 96 kHz."
Old 11-06-2021, 10:55 AM
JFreak's Avatar
JFreak JFreak is online now
Yes, but without having a Carbon here, I am interested in this very important detail: IS IT POSSIBLE to output SPDIF optical outside of PT software or is it PT only?
Janne
Old 11-06-2021, 11:07 AM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Yes, outside of PT as well. PT Hardware Setup just allows you to select which format you want for the optical output ports.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 11-06-2021, 11:38 AM
JFreak's Avatar
So this works even if you use another DAW?
Janne
Old 11-06-2021, 12:47 PM
Yes.
Kyle Splittgerber
Berkeley, CA
  #16
Old 11-07-2021, 07:35 AM
digiot digiot is offline
Optical Out Format
Thanks for clarifying that’s exciting news! I’m still holding off on the update because of the “connection loss” issues people have been reporting.
  #17
Old 11-09-2021, 07:02 AM
Southsidemusic's Avatar
Default Can anyone do a step by step on using the optical as adat
Been trying to get our two TC Clarity M stereo units working now when the Optical ports on Carbon is supposed to work as adat/spdif and I connected one optican from the TC to Carbon optical port and I dont know where to change the settings in the software and or PTultimate as I cant get the TC to get a connection green light. Been called by support but as time difference seem to be 9 hrs we were in the middle of tracking so my phone wasn’t even on so I really understand why people get green in their face grying to get and help with a 4000 dollar interface and mind you we bought 2 Carbon and with conversion it is about 9700-10.000 USD for both so please can eddie or someone else who knows this help please!? Been helping you (Avid) for 8-9 years so Think I am entitled to 5 minutes of your time?
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #18
Old 11-09-2021, 07:19 AM
Thanks for all your input but can Kyle or eddie for example show me how to as the page setup in carbon the left 2 boxes says N/A in Carborn page weather i set the right boxes to any of the choices. The 2 left boxes where I presume I should be able to chose adat/aes/spdif says N/A so where am i missing a setting? In PT or Audio-midi setup or where?
Thanks
Removed my older thread as it didn’t work with the old version but should be working now with new Carbon Firmware and PT2021.10
Here is the new post I wrote today and this shouldn’t be sooo difficult!
Best Regards
Christopher
#thestruggleisreal
WEBHOME
  #19
Old 11-09-2021, 07:42 AM
BScout BScout is offline
Default Re: Can anyone do a step by step on using the optical as adat
TC Clarity M stereo only accepts SPDIF signal (not ADAT)
To change what the Carbon is sending, in Pro Tools, go to Hardware Setup, Optical I/O page.
Switch this to S/PDIF
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
  #20
Old 11-09-2021, 08:05 AM
Check out Page 19 of What’s New guide which has the relevant Optical S/PDIF routing info. Ensure that the ADAT OUT port you’re connecting the optical cable to on Carbon is configured for S/PDIF in Hardware Setup.
What's the Input Mode (2) set to on the Clarity's System page? I'm looking at Page 15 in the guide and looks like you may be able to switch that between AES and S/PDIF. But, I have never used the Clarity device so I don't know how it needs to be configured.
Kyle Splittgerber
Berkeley, CA
TC Clarity X antonis Post - Surround - Video 0 05-02-2018 09:32 AM
TC Clarity M priorytools Avid Pro Mixing General Discussion 1 09-08-2016 01:10 PM
Is anyone using Clarity X? antonis Post - Surround - Video 0 03-08-2016 06:15 AM
Mic clarity bannerj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-21-2004 09:07 AM
Clarity in mixes citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 29 06-20-2002 10:54 AM
