Old 02-23-2016, 09:37 PM
bbrisk bbrisk is offline
Default Best way to print/export tracks for an entire session
Hello everyone,
I currently have session files saved for every song on my bands album; on each session file is roughly 24 audio tracks with most tracks containing plugins.
I am trying to find the best way possible to consolidate all of these audio tracks with their included plugins so the files can be sent to a studio to be mixed.
I am running Pro Tools 10 on a Windows 7 PC.
My current process:
  1. Consolidate audio tracks (preserving fades)
  2. Apply plugins straight to audio tracks by "Render" through AudioSuite
Issue: Certain plug-ins do not have a "save" function for their presets and do not appear under the "AudioSuite" tab.
My work-around for the above:
Print the entire audio track through a bus
I have noticed that the printed tracks do not match, and fall behind in length. I am assuming there is some type of latency issue involved here yet I am unsure what my buffer should be set to when printing tracks like this, right now I have it set to 1024. (128 - 2048)
Hopefully its not an issue with my PC
Moving the printed tracks to align them with the originals (there has to be a better solution)
Once all these steps have been performed I export the track as "New AAF/OMF"
I was hoping there is an option within "Bounce to" or "Export" that I don't know about which will bounce all of the audio tracks into separate files with plugins applied to their tracks.
Any help here would be greatly appreciated as I feel like I am making things harder than they need to be!
Old 02-24-2016, 05:21 AM
Default Re: Best way to print/export tracks for an entire session
Here's what I do:
Consolidate all tracks so they all have the same starting point on the timeline. For any tracks with fx or unrendered vi's I record them to a new audio track in real time. That way if/when in the future I need to do something with those tracks I have the audio and don't have to worry if I still have the plugins used on said tracks. That also will work if you're taking the tracks to another studio. And when you do do that just take the audio tracks with you, with each session in it's own folder. I don't muck about with aaf/omf - just pure audio.
Keep in mind that not all developers support AudioSuite usage. Native Instruments is but one.
Jack
QAPLA!
Old 02-24-2016, 06:30 AM
Benny_Cha_Cha Benny_Cha_Cha is offline
Upgrade to PT 12 and use Track Commit. Easiest way.
Ben Rubin
Producer//Mixer//Bassist//Composer
benrubin.com
PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive,
Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1
Old 02-24-2016, 07:00 AM
If this is a significant part of your workflow you should be on PT12.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 02-24-2016, 09:33 AM
While Pro Tools 12 and track commit would be excellent I don't have the funding to upgrade at this moment, if there are not any functions available which will bounce all the tracks separate with plug ins I will need to try different buffer settings that will allow printing tracks with minimal latency.
Old 02-24-2016, 01:27 PM
Buffer settings have no effect on latency when printing tracks that are totally in the box. I already gave you a method that will work.
Jack
QAPLA!
Old 02-24-2016, 04:37 PM
Then invest in Keyboard Maestro and write a macro to bounce each track separately.
Ben Rubin
benrubin.com
Old 02-24-2016, 04:40 PM
10 does not provide any offline bounce functionality, so your best bet will be to print through buses. You should not be having latency issues if all is well in your system. As Musicman pointed out, buffer should not effect latency assuming your within the range of your ADC to compensate.
Old 03-02-2016, 01:07 PM
Ive found that the best way is to assign tracks to a bus and then "Bounce to disk" from that bus and then import the files onto the track (eliminating all latency issues I was receiving), it is a simple process but quite time consuming.
I am going to look into ProTools 12 once I have my finances straight, thank you for all the help.
Old 03-02-2016, 01:37 PM
c-tone c-tone is offline
Make sure delay compensation is turned on.
Also, be aware that many (if not most) mixers prefer that you don't commit all the plug ins to the audio files so that they can choose their own processing, particularly for compression and EQ. If there are plug ins that are critical to the sound, such as amp simulator plugins, virtual instrument plug-ins, special effects, etc., then commit those and possibly send the unprocessed files as well to give the mixer options. Unless you were specifically asked by the mixer to do what are are trying to, then you could just send the session with the plug-ins inserted on the channel as you had them.
www.clifnorrell.com
Export selected tracks as new session - all audio? Schottlandru Pro Tools 10 3 06-05-2013 08:17 AM
export selected tracks as new session? FilterDecay Pro Tools 10 6 11-21-2011 01:11 PM
Export Selected Tracks as New Session PT 7-9 Dizzi45Z Pro Tools 10 3 11-17-2011 02:49 AM
Export Tracks to Session, Feature Request... JR Fountain Post - Surround - Video 9 09-07-2011 04:23 AM
Copy entire tracks from one session to another? JBz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-20-2006 03:35 PM
