Old 02-13-2005, 04:26 PM
Toonvox Toonvox is offline
Default Best sub-$500 Touch Control Surface?
That is if there is such a thing. I do use Command|8 at work, but I'm looking for a smaller transportable touch-sensitive (mix memory) control surface to use with an MBox system. It'll be mostly for commercial and voiceover production (w/sfx and recorded music) rather than live music.
I messed around with the Tascam US-428, but that was kind of a toy. From what I read here, the Behringer BCF2000's motorized faders don't quite do the trick (although I haven't read anyone using the auto-latch mode). If anyone can set me in the right direction, I'd appreciate it! Thanks.
PT 9.0.6
Digi002
iMac 2.7 GHz Intel i5 / 16gb RAM
OS X 10.8.5
Too many hard drives to count
Old 02-13-2005, 07:06 PM
Gkyaun Gkyaun is offline
Default Re: Best sub-$500 Touch Control Surface?
try motormix or something. the US428 sucks, i had one. note the "had", heh. but i think the motormix's are pretty cheap. and dang good.
sincerly mine, always and forever,
Gkyaun
go left next time
003 control surface (As audio) & control 24 as surface crizdee ProControl, Control|24, Command|8 7 01-04-2016 01:30 PM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 01:51 AM
Touch to select on MC mix, does control touch screen follow? Led Artist Series 0 03-24-2011 06:36 AM
003 Surface auto write/latch/touch buttons not working Arya44 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-19-2009 11:35 AM
Touch Screen Control Surface? joy4u Tips & Tricks 2 11-30-2001 02:30 AM
