Re: Record enabled tracks playing back early
LLM is the only way i know of, that lets me turn off software monitoring in pt. I monitor through an external desk, that‘s why I need it and don‘t find it useless if it works. The bug discussed here is abstinent in 2018.4 as far is i know.
has this issue been resolved? as the original poster suggested, it's a fairly new issue (post 2018) but still exists in current versions of pt (as of 2023). it happens with apollo AND carbon interfaces...both exhibit this annoying early playback on record enabled tracks. it's not a LLM issue. LLM is not even available when running carbon interfaces. i do wonder if teh presence of VI's in my session like Kontakt etc., have anything to do with it. My next step is to leave PT behind for good unfortunately. none of the other daws i use exhibit this issue with the same plugs and hardware. never used to happen in the pre 2020 era.
Christopher Stevens producer/writer/mixer Fabmusic/CS Productions Nashville, TN www.fabmusic.com |
Do you have ignore errors enabled? Try turning that off, works around similar issues in other user cases.
There are too many ADC related stupid bugs in Pro Tools, that need attention. Unclear why Avid is unable to address these issues. |
I don’t think so.. I just don’t put plugins on the stuff I’m recording or things I wanna playback. It’s not a great workaround, I know.. but it’s the only way I’ve found that works.
ADC causes early playback on record enabled track [solved] | camnicklaus | Pro Tools 12 | 14 | 02-03-2017 06:22 PM |
Record enabled tracks disengage after I stop playback when listening back to take? | stevebeacham | Pro Tools 10 | 14 | 10-25-2016 08:07 AM |
Recorded audio playing back too early | jonwade92 | macOS | 3 | 04-15-2013 01:01 PM |
Recorded are sounds playing back early?? | thierryhenry | macOS | 2 | 03-12-2013 11:26 AM |
No sound when playing back with record enabled | mhvoiceuk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-01-2007 12:27 PM |
