Old 02-24-2004, 08:38 AM
Belle Belle is offline
Default OMS won\'t install on macOSX .help!
I'm new at this, just got my mbox , trying to intall pro-tools but it won't work without the OMS, and OMS isn't installing on my computer. I'm on OSX and my hard drive has no partitions. Can anyone help. If I upgrade to OSX Pro-tools LE , will i need OMS still?
how can I solve this?
thanxxx
Old 02-24-2004, 08:41 AM
reztowel reztowel is offline
Default Re: OMS won\'t install on macOSX .help!
You don't need OMS on OSX. You deal with these issues with the "Audio MIDI Setup" in your "Applications/Utilities" folder.
Old 02-24-2004, 08:44 AM
41217 41217 is offline
OMS does not run under OSX, It only works with Protools under OS9! iNstead Didi use AMS, IS that what you mean??
Old 02-24-2004, 08:47 AM
but my pro-tols won't even starrt running.. what do i do in the folder?
sorry.. i'm an absolute newby.
x
Old 02-24-2004, 08:50 AM
Slim Shady Slim Shady is offline
Sounds like you are trying to install ProTools 5.x in the classic environment - This absolutely will not work. You must have PT 6.x to run in OS X (check the compatibility pages). Please post more info about your system (OS version, computer model, amount of RAM etc.), and we can help you with exactly which version you need to upgrade to.
Old 02-24-2004, 08:53 AM
I have the installer CD for LE 5.2.1 , my system in OSX 10.2.8 , i have no partitions . How can i upgrade, do I have to purchase any software ?
When i try to run pro-tools, it come on classic, but it stop saying there was a problem with the DAE , and when i intalled it it said i needed OMS .
thanxxx
Old 02-24-2004, 09:20 AM
pk_hat pk_hat is offline
Only PT 6 and up will run in OSX.
More info here.
www.myspace.com/krou
Old 02-24-2004, 09:36 AM
hi slim,
do you know what is the procedure to save all my info and software before i do partition my hard disc ?
x
Old 02-24-2004, 09:39 AM
HI, the error that shows up is DAE error -6009
x
Old 02-24-2004, 09:43 AM
clockface clockface is offline
Hi, you do not need to partition your HD. You need to either boot your computer in OS 9 and reinstall PT 5 with OMS, or you need to purchase the PT 6 upgrade and install that in OSx. Your software will not work in OS 10.anything. Period. And with PT 5, you will need to boot in OS 9 every time you want to use the program, it will not work in OSx/Classic. Hope this helps.
PT 10.3.4 and MacOSX 10.6.8 rrongman macOS 3 04-08-2013 09:37 AM
Have to install pace extension software each time I start Macosx before PT9 will load belolab Pro Tools TDM Systems (Mac) 11 07-27-2011 05:23 PM
Can i keep both PT 7.4.2 and DP 6 on the same MacOSX 10.5.3 ?? petja Pro Tools TDM Systems (Mac) 2 04-27-2009 02:03 PM
003+Macosx neilcash05 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-18-2008 06:15 AM
Problem after install ProTools HD 7.3.1cs5 update for MACOSx onut Pro Tools M-Powered (Mac) 5 10-27-2007 09:38 PM
