Solo not working
I just upgraded to PT 2021 and the solo buttons on any channel is not working.
They light up with no effect and none of the solo safes are on. Mutes are working just fine. Looking for suggestions to why this might be happening. |
Re: Solo not working
No info abt your system. 🤦🏻*♂️
It’s working just fine here…
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
More info would be helpful, but first check solo modes under the Options menu. If you're in AFL/PFL mode you'll need to define an output bus under the "output" tab in the I/O setup - not necessary if you're in SIP mode. Also, it's possible you've command-clicked the solo buttons to disable them.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Solo not working | deslog | macOS | 4 | 09-11-2018 12:36 PM |
Solo isn't working right | legacygt777 | Pro Tools 10 | 6 | 04-03-2018 07:49 PM |
Solo bus not working after bus changes | Audioartist | Pro Tools HDX & HD Native Systems (Mac) | 0 | 05-28-2017 02:23 AM |
Solo Clear not working on S3 | jmkeane | Avid S1, S3, Dock and Control App | 3 | 10-09-2015 07:34 AM |
Protools 10: mute and solo aren't working. (Solo safe is not on any of the tracks.) | charlottewrinch | macOS | 2 | 04-14-2012 05:32 PM |
